Solving the Wave Equation via complex coordinates
5 replies · 2K views · last reply
jk22
I'm looking for material about the following approach : If one suppose a function over complex numbers ##f(x+iy)## then
##\frac{df}{dz}=\frac{\partial f}{\partial x}\frac{1}{\frac{\partial z}{\partial x}}+\frac{\partial f}{\partial y}\frac{1}{\frac{\partial z}{\partial y}}=\frac{\partial f}{\partial x}-i \frac{\partial f}{\partial y}##
Hence the wave equation with source g reads
##Re(\frac{\partial^2 f}{\partial z^2})=g(x+iy)##
Using Cauchy residue theorem
##Im(\oint\frac{f(z)}{(z-a)^3}dz)=\pi g(a)##
Then if the source is the function itself we can obtain the total function out of the contour integral over the boundary condition for example.
However I seek to use this method to solve the wave equation given another source and don't know how to solve the integral equation. Does anyone know how this could be done ?
You can write the Laplacian in terms of complex co-ordinates, I'm not sure you can do this for the wave equation though, as you have a minus sign to contend with.
Ok, I have to check, but is it correct that gives the solution of the Klein-Gordon equation with a quantization due to the winding number ?
Oops, I made mistakes.
1) ##\frac{d}{dz}=\frac{1}{2}(\frac{\partial}{\partial x}-i\frac{\partial}{\partial y})##
I forgot also that ##y=ct##
Then we have to derive twice
##f(z)=\frac{n_\gamma(z)}{2\pi i}\oint_\gamma\frac{f(s)}{z-s}ds##
Towards ##z## :
##\frac{d^2}{dz^2}=\frac{\partial^2}{\partial x^2}-\frac{1}{c^2}\frac{\partial^2}{\partial t^2}-2i\frac{\partial}{\partial x}\frac{\partial}{c\partial t}##
This seems more clear to ask the questions :
1) is the product of operator derivative a second order derivative or the square of the first derivative : ##\frac{\partial^2\psi(x,t)}{\partial x^2}\neq\left(\frac{\partial\psi(x,t)}{\partial x}\right)^2##
2) in deriving the Cauchy formula wrt. ##z## assuming the endstate were zero as well as the boundary but the initial state uniformly distributed, then there are 3 termd, the first involving second derivative of ##n_\gamma(z)## which gives a derivative of a delta and the integral gives a log type result. I don't know if this is correct ?
But assuming this would imply the square of the log is decreasing and then increasing, like a Bell signal.
But increasing signals with the distance is contrary to all forces in the nature ? Hence there shall be a maximal distance for intrication ?
Erratum : the imaginary part of theexpression in the integral is of the form ##\frac{ct}{(x-s)^2+c^2t^2}ds## so it is not a log but an arctan.
Addendum : if this is correct it could permit in particular to solve a lot of equations of the type ##\box\psi=f(\psi)## even with the requirement of compactness between an initial and and a final condition.
(Could The compactness solve for example the problem of infinite speed of diffusion of a delta localized particle ?)
