Solving Two Ballistics Problems
  • Thread starter Thread starter black_hole
    Ballistics
7 replies · 2K views
black_hole
I need help with these 2 problems:
A hunter aims directly at a target (on the same level) 81 m away. If the bullet leaves the gun at a speed of 225 m/s, how far below the target will the bullet hit?
A rifle bullet is fired at an angle of 15.2° below the horizontal with an initial velocity of 154 m/s from the top of a cliff 63.9 m high. How far from the base of the cliff does it strike the level ground below?
Vx = 225 m/s, x = 81 m
Vyo = 0 m/s ?
a = -9.8 m/s/s, t = .36 s (from Vx = x/t)
so I used y = volt + at^2 to find y, but that's not right...
and for the second one
Vx = 148.613 m/s
Vo = -40.377 m/s, a = -9.8 m/s/s, y = -63.9 m
using the same equation, t = 1.221 s
and V = x/t, x= 181.456 m
again, not right. help please.
You're just missing a 1/2 in your equation here:
y = volt + at^2
Vyo = 0 m/s ?
Vx = 148.613 m/s
In the first one, you're just missing a 1/2 in your equation here:
y = volt + at^2
Wow, how embarrassing. However, in the 2nd one. I now get 201.965 m, which is not right?
Could you please show your new work for the 2nd one?
well, using the correct equation y = Vo + 1/2at^2 and keeping everything the same
Vx = 148.613 m/s
I found t = 1.359 s
and V = x/t, x= 201.965 m...
black_hole said:
y = Vo + 1/2at^2
The bullet in the 2nd problem is fired downward, so it's initial y velocity is not zero...
Vx = 148.613 m/s
I found t = 1.359 s
I meant y = volt + 1/2at^2
I'm sorry if I was not clear, but Vyo = -40.377 m/s
That looks mostly right then, unless there is a small rounding error or something. Is it not the right answer? If not, could you please write out each step again, and I;ll do a more careful check of the math. (I'm bailing for a couple hours though -- will try to check back a bit later)
