Solving x^3 + 1/x^3 ≥ 3
9 replies · 2K views · last reply
mathdad
Section 2.6
Question 82
Solve: x^3 + (1/x^3) ≥ 3. (Use a calculator to approximate the key numbers.)
I need someone to get me started.
Mathematics news on Phys.org
Move everything to the LHS, and then combine all terms into a rational expression...what do you then have?
x^3 + (1/x^3) - 3 ≥ 0
x^3(x^3) + [(1/x^3)](x^3)/1 -3x^3 ≥ 0
x^6 + 1 - 3x^3 ≥ 0
x^6 - 3x^3 + 1 ≥ 0
I am stuck here.
What you should have is:
$$\frac{x^6-3x^3+1}{x^3}\ge0$$
Recall, you don't want to multiply an inequality by an expression having an unknown sign.
We have a 6th degree polynomial in the numerator, and so the fundamental theorem of algebra tells us that we should expect to find 6 roots...what does Descartes' rule of signs tell us about these roots? Do you recognize that you can treat the numerator like a quadratic?
"Recall, you don't want to multiply an inequality by an expression having an unknown sign."
Yes, I forgot that important rule.
"We have a 6th degree polynomial in the numerator, and so the fundamental theorem of algebra tells us that we should expect to find 6 roots."
What is the Fund. Theo. of Algebra?"What does Descartes' rule of signs tell us about these roots?"
I am not there in the textbook and thus, do not know this rule.
"Do you recognize that you can treat the numerator like a quadratic?"
Can the numerator by written as (x^2)^3 - 3x^3 + 1?
One of the proven assertions of the FTOA is:
A polynomial of degree n will have exactly n roots (counting multiplicity).
That's why I provided a link...it is a useful rule when studying polynomials, and its usage is within the grasp of the Pre-Calc student. I advise you to read the information to which I linked, and let me know what this rule says about the roots of the polynomial under consideration here.
No, this is what I mean:
$$(x^3)^2-3x^3+1$$
We have a quadratic in $x^3$. This will give you two of the roots, and you should be able to use Descartes' rule of signs to determine if there are any other real roots. :D
The expression (x^3)^2 - 3x^3 + 1 cannot be factored.
It has no rational roots, but we can use the quadratic formula to state:
$$x^3=\frac{3\pm\sqrt{5}}{2}\implies x=\sqrt[3]{\frac{3\pm\sqrt{5}}{2}}$$
Descartes' rule of signs indicates that the remaining roots must be complex, and so these two real roots are all we need to be concerned about. So, you have 3 critical values, all of which are roots of odd multiplicity, so you know what to do from here. :D
Thanks. I will need to use my calculator. The critical values are complicated. They belong on the number line and the rest remains the same steps, right?
Let CR = CUBE ROOT
Let SR = SQUARE ROOTCR{(3 - SR{5})/2} = x which is about 0.7256
CR{(3 + SR{5})/2} = x which is about 1.378
<----------(0.7256)----------(1.378)----------->
For (-infinity, 0.7256), let x = 0. True statement.
For (0.7256, 1.378), let x = 1.2. False statement.
For (1.378, infinity), let x = 4. True statement.
We exclude the critical points.
Solution:
(-infinity, 0.7256) U (1.378, infinity)
Correct?
