Solving y' = 3x²/(3y² - 4) with y(1) = 0
11 replies · 7K views · last reply
alane1994
Here is my question:
Solve the initial value problem
\(y\prime=\dfrac{3x^2}{3y^2-4},~y(1)=0\)
and determine the interval in which the solution if valid.
Hint: To find the interval of definition, look for points where the integral curve has a vertical tangent.
My work so far:
\(y\prime=\dfrac{3x^2}{3y^2-4}\)
\(\dfrac{dy}{dx}=\dfrac{3x^2}{3y^2-4}\)
\((3y^2-4)dx=(3x^2)dx\)
\(\int (3y^2-4)dy=\int (3x^2)dx\)
\(y^3-4y=x^3+C,~C=-1\)
\(y^3-4y=x^3-1\)
And this is where I am at so far. If you could tell me if this is correct as of yet, and guide me to the final destination of this problem, that would be joyous!
My work so far:
\(y^3-4y=x^3-1\)
Hi alane1994!
Yes. That is correct.
You do have a typo. It should be \( (3y^2-4)d\color{red}{\mathbf y}=(3x^2)dx \).
To find a vertical tangent you need a point where $dx/dy=0$.
I suggest you substitute $dx=0$ in \( (3y^2-4)dy=(3x^2)dx \) and solve it.
If \(\dfrac{dy}{dx}=0\), does that not mean that the slope is zero and as such the line is horizontal?
Yes.
That is why I mentioned \(\dfrac{dx}{dy}=0\) instead (x and y swapped).
Aha, I feel silly now, I feel very silly indeed.
When I do that and solve for y, I get:
\(y=\pm2,~0\)
\(y=\pm2,~0\)
That doesn't sound right.
I don't think that is the solution of $3y^2 - 4 = 0$.
alane1994 said:
Isn't it \((3y^2-4)dy=0\)?
Yes. And we'll assume (for now) that $dy \ne 0$.
When we substitute one of your solutions, say $y=2$, we get:
$$(3y^2-4)dy = (3 \cdot 2^2 - 4) dy = 8dy \ne 0$$
So $y=2$ is not a solution.
But what I am saying, is that the dy means that it is a derivative of something yes? so to solve for y truly, you need to take the integral of it, and then solve for y. Right?
Not really.
You can rewrite your original differential equation $$\frac{dy}{dx}=\frac{3x^2}{3y^2−4}$$ as $$\frac{dx}{dy}=\frac{3y^2−4}{3x^2}$$ due to the Inverse function theorem. After that you can equate it to 0 and solve it, yielding vertical tangents.Anyway, as I like to see it, $dy$ means that you change the y coordinate by a very small amount. As a result the x coordinate also changes by an amount $dx$.
Their ratio happens to be the derivative, when we take those changes to the limit of 0.
But if you want, you can also look at it as x being a function of y, the inverse function.
The symbol $y$ is actually the function $y(x)$. If that function is invertible, then its inverse can be written as $x(y)=y^{-1}(y)$.
The derivative of $y(x)$ is $\frac{dy}{dx}$. The derivative of its inverse is $\frac{dx}{dy}$.
