Solving y' = 4e^{0.8x}-0.5y with integrating factor
  • Thread starter Thread starter bsodmike
    Ode
7 replies · 4K views · last reply
bsodmike
Going through a book on Numerical Methods, it states,
[tex]y' = 4e^{0.8x}-0.5y[/tex]
has the analytical solution,
[tex]y= \dfrac{4}{1.3}(e^{0.8x}-e^{-0.5x})+2e^{-0.5x}[/tex]
This is of the form,
[tex]y'+p(x)y=q(x)[/tex]
Should I use an Integrating Factor to solve the Linear ODE?, i.e. use an integrating factor [tex]\mu(x)=e^{\int{p(x)dx}}[/tex]
[tex]\mu(x)\left[y'+p(x)y\right]=\mu(x)q(x)[/tex]
[tex]\left(\mu(x)y\right)'=\mu(x)q(x)[/tex]
[tex]\mu(x)y=\int{\mu(x)q(x)dx+C}[/tex]
...and divide through by [tex]\mu(x)[/tex] ?
[tex]\mu(x)=e^{\int{p(x)dx}}=e^{0.5x}[/tex]
thus,
[tex]e^{0.5x}y=4\int{e^{0.8x}e^{0.5x}dx+C}[/tex]
and it is given: y(0) = 2
Any pointers? Dick, your help would be much appreciated once again!
Thanks and happy new year to all as well,
Cheers
Mike
When computing your integrating factor what did you use as your p(t)? Your integrating factor is not correct.
Note: with p(t)dt, consider it as p(x)dx. I used some old latex definition I had already typed for the 'method'. i.e., rather than dy/dt, this is dy,dx. dy/dt = f(t,y) -> dy/dx = f(x,y).
*Definition updated in OP, w.r.t to (x).
I used,
[tex]\mu(x) = e^{\int{p(x)dx}}=e^{\int{\dfrac{1}{2}dx}} = e^{0.5x}[/tex]
Well, isn't this,
[tex]y'+0.5y=4e^{0.8x}=y'+p(x)y=q(x)[/tex]
hence, [tex]p(x)=0.5[/tex] and [tex]q(x)=4e^{0.8x}[/tex] ?
[tex]e^{\int{\dfrac{1}{2}dx}}[/tex] Try doing this integral again. Where did the ln 2 come from?
Oooops! thanks for spotting that blatant error. [tex]IF=e^{\int{p(x)dx}}=e^{0.5x}[/tex].
This is what I am getting now,
Since,
[tex]\mu(x)=e^{\int{0.5\,dx}}=e^{0.5x}[/tex]
[tex]\begin{equation}\begin{split} <br /> e^{0.5x}y&=4\int{e^{1.3x}}\,dx+C\\<br /> &=4\left(\dfrac{e^{1.3x}}{1.3}\right)+C\\<br /> &=\dfrac{4}{1.3}e^{1.3x}+C<br /> \label{eq:}<br /> \end{split}\end{equation}[/tex]
Hence,
[tex]\begin{equation}\begin{split} <br /> y=\dfrac{4}{1.3}e^{0.8x}+Ce^{-0.5x}<br /> \label{eq:}<br /> \end{split}\end{equation}[/tex]
Where am I going wrong again?!?
*bump*
When I left the problem earlier as [tex]e^{0.5x}y=4\int{e^{0.8x}e^{0.5x}\,dx}+C[/tex], I thought I'd need to use integration by parts. But once I got it in the simpler form above (adding the powers) it just seems 'too simple' and the solution is missing a term.
*confused*...hmm..
