Some clarifications on my proving
  • Context: Graduate
  • Thread starter Thread starter relinquished™
The discussion revolves around the proof of the proposition "If a set S is dense, then every point in S is an accumulation point." Participants explore the implications of density in the context of real analysis, addressing assumptions and clarifications regarding the proof structure.
  • One participant proposes assuming the contrary of the proposition to derive a contradiction, suggesting that if S is dense, then no points in S can be non-accumulation points.
  • Another participant questions the definition of density, asking if it pertains to the real numbers and whether accumulation points are being correctly defined.
  • Clarifications are made regarding the meaning of density, with some participants asserting that S is dense in the real numbers, implying that for any two real numbers a and b, there exists an element s in S such that a < s < b.
  • Concerns are raised about whether points a and b can be assumed to be in the deleted ε-neighborhood of x, given the condition a < x < b.
  • One participant emphasizes that deleted neighborhoods are open sets and that unions of open sets remain open, which is relevant to the proof structure.
  • Another participant expresses uncertainty about the implications of assuming S is dense and how it relates to proving that x is not an accumulation point.
Participants express varying levels of understanding regarding the proof and the definitions involved. While some agree on the implications of density, others raise questions about the assumptions made in the proof, indicating that multiple competing views remain on the interpretation of the concepts discussed.
Limitations in the discussion include unclear definitions of density and accumulation points, as well as the need for further clarification on the structure of neighborhoods in the context of real analysis.
relinquished™
Hello. I didn't know if this is the right forum to post this (since this is the Calculus section and my question pertains to real analysis), but I would like some clarifications on a proof I am preparing for the propositon "If a set S is dense, then every point in S is an accumulation point".
What I did is assume the contrary, that is, "If a set S is dense then none of its points are accumulation points". Then for an arbitrary element x in S it is possible to create a deleted ε-neighborhood for any ε>0 such that (x-ε, x+ε) does not contain any point in S. Now, i let a and b be elements in S such that a < x < b such that x-a = b-x. If I assign ε=b-x (in turn, ε=x-a), then the deleted neighborhood for this choice of ε must be empty to guarantee that x is not an accumulation point, that is, (a,x)U(x,b) should be empty, which means (a,x) is empty and (x,b) is also empty. This means that there are no numbers between a and x and between x and b, which means that S is not dense (since a dense set is defined to be that for any elements c and e and c<e there exists an element d such that c < d < e), which leads to a contradiction since we assume S to be dense. Hence, If a set S is dense, then every real point in S is an accumulation point. ///
My questions are:
(1) can I simply assume that x is between a and b since S is dense?
(2) If I choose my ε to be b-x, are a and b in the neighborhood of x? this also leads to the question that are deleted neighborhoods open sets...
Thanks for any help.
What do you mean by "a set S is dense"? I know what it means to say that a set is dense in some larger space. Do you mean dense in the real numbers? You appear to be assuming that S is a set of real numbers. And do you mean to say, then an accumulation point of the set of real numbers?
From what I understand, he/she is saying that S is dense in the set of real numbers... continuing further, if a and are real nos. and a < b, there is an s belonging to S such that a < s < b.
This section is called "Calculus & Analysis" so it looks like a good place.
As has been mentioned Set density is with respect to another set
as in S is dense it S'
next the contrary to
is
"If S there exist a one point in S that is not an accumulation point, then S is not dense."
so (assuming you mean S is dense in R)
Let x be a point in S that is not a point of accumulation and show that S is not dense.
You are on the right track
I do not understant this
deleted neighbor hoods are open
unions of open sets are open and a deleted neighborhood is a union of open sets in R1.
HallsOfIvy
Sorry for not making the definition of Denseness clear. Irony of Truth just spelled it out for me: S is dense in the set of real numbers... continuing further, if a and are real nos. and a < b, there is an s belonging to S such that a < s < b.
Also, the propostition should be: "If a set S is dense, then every point in S is an accumulation point of set S".
Sorry again for the incompleteness of my statements and proposition.
Irony_Of_Truth
I'm a he ^_^;; Thanks by the way for clearing things up.
lurflurf
When I meant "can I assume that a < x < b" I was asking if I could assume that x will be between two numbers, sa a and b, that is in set S such that a < x < b because of the Denseness of S
Generally, the thing I'm bothered with is whether or not a and b should be in the deleted ε neighborhood of my arbitrary point x under the assumption that a < x < b, that x-a = b-x and if my chosen ε > 0 would assume a value of ε=x-a (in turn, ε=b-x).
I would also appreciate it if anyone can find any potholes in my proof :)
Thanks in advance :)
relinquished™ said:
lurflurf
well you have found that
x is not an accumulation point-> there exit (a,x)U(x,b)
thus S is not dense
clearly a and be are not is (a,x)U(x,b)
(you could also say intersection((a,b),S)={x})
you need not be concerned about denseness other than showing since x is not a point of accumulation S is not dense.
I do not see how assuming S dense helps
sketch of proof
1) let x in S not be a point of accumulation
2) then there exist a deleted neighbor of x with nothing in common with S
3) S is not dense in R because (a,x) does not cointain a point in S
you should not say (a,x) is empty (though perhaps you could if your universe were S) it is better to say (a,x) contains not points from S.
I see... a and b are not in the deleted ε neighborhood of x when ε=x-a. Thanks for the clarifications. :) I really appreciate the help :)
  • · Replies 25 ·
