Some questions about linear transformation
A linear transformation is defined as a special type of function that satisfies specific properties, namely T(cu + dv) = cT(u) + dT(v) and T(cu) = cT(u) for all vectors u, v and scalars c, d. The superposition principle describes how linear transformations can be expressed as a linear combination of inputs and their corresponding outputs, reinforcing the linearity of the system. The discussion seeks clarification on these concepts, confirming the accuracy of the statements made about linear transformations and the superposition principle. Participants are encouraged to provide further insights or improved explanations. Overall, the thread emphasizes understanding the foundational principles of linear transformations in linear algebra.
Eus
Hi Ho! ^^v
I've some questions regarding linear transformation in my linear algebra course, guys!
Please help me! ^^v
Statement: A linear transformation is a special type of function.
My answer: Yes, it is a special type of function because it must satisfy the following properties from the definition of linear transformations which is
A transformation (or mapping) T is linear if:
1. T(c u + d v) = c T(u) + d T(v) for all u, v in the domain of T;
2. T(c u) = c T(u) for all u and all scalars c.
Am I right?
Statement: The superposition principle is a physical description of a linear transformation.
Note: In my book it is written, I rephrased it, the superposition principle is defined as the generalization of the definition of linear transformation (i.e. T(c1 v1 + ... + cp vp) = c1 T(v1) + ... + cp T(vp) for v1...vp in the domain of T and c1...cp are scalars)
My answer: Yes, it is because a physical event can be determined to be linear if the "input" conditions can be expressed as a linear combination of such "input" and the system's response is the same linear combination of the responses to the indiviual "input".
Am I right?
Maybe you could provide me with a better answer, please? ^^
Thank you very much, guys!
Any help would be appreciated! ^^v
Mathematics news on Phys.org
Yes, you are correct. Sorry you had to wait 12 years for an answer.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 23 ·
