Something about hermitian matrixes
  • Thread starter Thread starter twoflower
    Hermitian
The discussion centers on the proof that all eigenvalues of a Hermitian matrix are real and that such matrices can be diagonalized by a unitary matrix. Participants clarify the properties of Hermitian matrices and the significance of unitary transformations in this context. A key point raised is the confusion regarding the transposition of matrices and the order reversal that occurs during this operation. The conversation also touches on the spectral decomposition of Hermitian operators in finite-dimensional spaces and the implications for the diagonalization process. Understanding these concepts is crucial for grasping the proof's structure and the properties of Hermitian matrices.
twoflower
Hi all,
I don't understand to one part of proof of this theorem:
All eigenvalues of each hermitian matrix A are real numbers and, moreover, there exists unitary matrix R such, that
<br /> R^{-1}AR<br />
is diagonal
Proof: By induction with respect to n (order of matrix A)
For n = 1 it's obvious.
Suppose that the theorem holds for 1, 2, ..., n-1
We know that \exists eigenvalue \lambda and appropriate eigenvector x \in \mathbb{C}.
Using Steinitz's theorem, we can extend x to orthonormal base of \mathbb{C}^{n}.
Suppose that ||x|| = 1 and construct matrix P_n from vectors of this base (P_n will have these vectors in its columns).
P_n is unitary \Leftarrow P_{n}^{H}P_n = I, because standard inner product of two different vectors in the orthonormal base is zero and inner product of two identical vectors is 1.
This holds:
<br /> \left(P_{n}^{H}A_{n}P_{n}\right)^{H} = P_{n}^{H}A_{n}^{H}\left(P_{n}^{H}\right)^{H} = P_{n}^{H}A_{n}P_{n}<br />
Last line is what I don't understand, probably it's trivial but I can't see that
<br /> \left(P_{n}^{H}A_{n}P_{n}\right)^{H} = \left(P_{n}^{H}\right)^{H}A_{n}^{H}P_{n}^{H} = P_{n}^{H}A_{n}^{H}\left(P_{n}^{H}\right)^{H}<br />
(the second equality)
Thank you for the explanation.
because you're forgetting that taking the daggeer reverses the order of the matrices i'l; use start instead, but (AB)*=B*A*
the second equality as you have it is wrong, but then it isn't supposed to be true.
Thank you a lot Matt, I was looking at it for ten minutes and it's as simple as normal transposition :rolleyes:
Well,the first part (the real values of eigenvalues of hermitean operators) can be proven quite easily for a hermitean linear operator defined on a dense everywhere subset of a separable Hilbert space.
Daniel.
The key to the second part is to remark that that matrix
M^{\dagger}AM \ ,\ M\in U(n,\mathbb{C})
is hermitean,which means that the linear operator associated is hermitean.A hermitean linear operator in a finite dimensional complex Hilbert space admits a spectral decomposition (moreover,the spectrum is purely discrete),which means that the operator M^{\dagger}AM has zero off-diagonal matrix elements.
Daniel.
Daniel.
Thank you Daniel for this explanation, but I don't have a clue what Hilbert space is (I only heard of it) and what hermitean linear operator is.
However, I've been studying the proof on and I again encountered place I don't understand to.
If I continue from where I finished my initial post:
And thus P_{n}^{H}A_{n}P_{n} is hermitian matrix.
Next,
<br /> \left( \begin{array}{cc} \lambda &amp; 0 ... 0 \\ 0 &amp; A_{n-1} \\ 0 \end{array} \right)<br />
Because this matrix is equal to its hermitian transposition, \lambda \in \mathbb{R}
// I'm not sure why this matrix is here and whether it should mean that it is the matrix P_{n}^{H}A_{n}P_{n}, I really don't know...anyway, let's continue
From induction presumption \exists unitary matrix R_{n-1} such, that
<br /> R_{n-1}^{-1}A_{n-1}R_{n-1} = D_{n-1}<br />
Let's take
<br /> S = \left(\begin{array}{cc} 1 &amp; 0 ... 0 \\ 0 &amp; R_{n-1} \\ 0 \end{array} \right)<br />
<br /> R_n = P_{n}S<br />
S is unitary, as well as P_{n}. Is also their product unitary? (In another words, is product of two unitary matrixes unitary matrix?) Let's see.
<br /> R_{n}^{H}R_{n} = \left(P_{n}S\right)^{H}P_{n}S = S^{H}P_{n}^{H}P_{n}S = I<br />
So, it holds that R_{n} is also unitary. Is R_{n} the matrix we're looking for?
<br /> R_{n}^{-1}A_{n}R_{n} = \left(P_{n}S\right)^{H}AP_{n}S = S^{H}P_{n}^{H}AP_{n}S = \left(\begin{array}{cc} 1 &amp; 0 ... 0 \\ 0 &amp; R_{n-1}^{H} \\ 0 \end{array} \right)<br /> \left(\begin{array}{cc} \lambda &amp; 0 ... 0 \\ 0 &amp; A_{n-1} \\ 0 \end{array} \right)<br /> \left(\begin{array}{cc} 1 &amp; 0 ... 0 \\ 0 &amp; R_{n-1} \\ 0 \end{array} \right) = <br /> \left(\begin{array}{cc} \lambda &amp; 0 ... 0 \\ 0 &amp; D_{n-1} \\ 0 \end{array} \right) = D<br />
Q.E.D
What I don't understand is that according to this,
<br /> P_{n}^{H}AP_{n} = \left(\begin{array}{cc} \lambda &amp; 0 ... 0 \\ 0 &amp; A_{n-1} \\ 0 \end{array} \right)<br />
Why?
Thank you.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 26 ·
