rahaverhma
- 73
- 1
Does space contract when one observes the space from the frame which is moving with relativistic velocity?
The discussion centers on the concept of length contraction in the context of relativistic velocities. When two objects are separated by a distance L at rest, an observer moving at a constant velocity v will measure the distance as L√(1-v²/c²). This phenomenon, commonly referred to as "length contraction," is distinct from the observer's visual perception of objects, which appear rotated rather than contracted. The conversation emphasizes that space should not be attributed physical characteristics, as it is fundamentally a geometric construct dependent on the observer's frame of reference.
PREREQUISITESPhysicists, students of relativity, and anyone interested in the implications of relativistic motion on measurements and observations in space.
If anything, space effectively expands for objects that move relative to you, because you can fit more of these objects into the same length, as measured by you. But we usually interpret this as the objects contracting, not as the space expanding.rahaverhma said:Does space contract when one observes the space from the frame which is moving with relativistic velocity?
No. A length is defined between to simulteneous events (!) and simultanity is relative, hence length contraction.rahaverhma said:Does space contract when one observes the space from the frame which is moving with relativistic velocity?
It is never a good idea to impart physical characteristics to space, which really is just geometry. Rather, it makes more sense to talk about the distance between objects and the length of objects, leaving space entirely out of the discussion.rahaverhma said:Does space contract ...
In particular as what ”space” is is observer dependent.phinds said:It is never a good idea to impart physical characteristics to space, which really is just geometry. Rather, it makes more sense to talk about the distance between objects and the length of objects, leaving space entirely out of the discussion.
