Space of continuous functions C[a,b]
The dimension of the space of continuous functions C[a,b] is infinite, as it includes all polynomials. The discussion centers on whether a Hamel basis for this space is countable or uncountable, with indications that it is uncountable. A proof without relying on a norm is sought, and a counting argument is suggested, highlighting that the cardinality of C[a,b] is the continuum. It is established that the set E = {e^ax | a real} is an uncountable linearly independent subset of C[a,b], reinforcing that C[a,b] cannot have a countable Hamel basis. The conversation also notes that while Hamel bases can be finite or uncountable, specific examples exist where a countable basis is possible, such as in the space of real sequences that are eventually zero.
ninty
We know that dim(C[a,b]) is infinte. Indeed it cannot be finite since it contains the set of all polynomials.
Is the dimension of a Hamel basis for it countable or uncountable?
I guess if we put a norm on it to make a Banach space, we could use Baire's to imply uncountable.
I am however interested in a proof that does not rely on equipping the vector space with a norm.
If it's too long winded but available somewhere else(books, articles) kindly point it out to me and I'll read it.
Hamel bases are always finite or uncountable.
That's true if your space is an infinite dimensional normed vector space which is complete, and that result follows from Baire's category theorem AFAIK. So you haven't really strayed from the original proof.
A counting argument might suffice. Suppose there was a countable basis. There are only continuum many choices of finite linear combinations from these, but the cardinality of the vector space is larger than that
I used instead the fact that exponentials are continuous
Then E:={e^ax : a real } is a subset of C[a,b]
It's clear that for finite n, {e^ix : i in N} is linearly independent.
I'm fudging, but that would seem to imply that E is also linearly independent, since every finite subset is linearly independent.
Hence cardinality of a basis is at least |E| = continuum
False: the cardinality of C[a,b] is the cardinality of the continuum. (Each function in C[a,b] is uniquely determined by its values on the rational numbers in [a,b].)
But yes, you could show that E = {eax | a real} is an uncountable linearly independent subset of C[a,b], to show that C[a,b] has no countable Hamel basis.
The space of all real sequences which are eventually zero has a countable Hamel basis.
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
10K
  • · Replies 25 ·
  • · Replies 24 ·
