Spaghettification & Black Holes: Classical & Einsteinian
The discussion centers on the phenomenon of spaghettification near black holes, comparing classical and Einsteinian models of gravity. Participants clarify that radial stretching and lateral squashing are both effects of differential gravity, with the Riemann curvature tensor providing the mathematical foundation for these observations in Schwarzschild spacetime. The conversation emphasizes that while the underlying concepts differ between Newtonian gravity and general relativity, the observable effects remain consistent. The role of tidal forces, particularly in the context of the Moon's influence on Earth's tides, is also highlighted as a practical analogy.
  • Understanding of general relativity concepts, particularly Schwarzschild spacetime.
  • Familiarity with the Riemann curvature tensor and its components.
  • Basic knowledge of tidal forces and their effects in gravitational fields.
  • Conceptual grasp of Newtonian gravity versus Einsteinian gravity.
  • Study the mathematical formulation of the Riemann curvature tensor in general relativity.
  • Explore the implications of tidal forces in astrophysical contexts, particularly near black holes.
  • Investigate the differences between Newtonian and Einsteinian models of gravity in detail.
  • Learn about Schwarzschild solutions and their applications in black hole physics.
Astronomers, physicists, and students of general relativity who seek to understand the effects of gravity near black holes and the mathematical principles underlying these phenomena.
DaveC426913
2025 Award
TL;DR
What is the source of the lateral "squashing" when falling into a black hole?
(Classical model)
The radial "stretching" is caused by differential gravity (tides), but what is the lateral squashing caused by? Is it because the "force" of gravity is not parallel, but instead comes from a point, forming an acute angle?
(Einsteinian model)
I guess it's pretty trivial to explain in curved spacetime - the curvature near a black hole can be measured both radially and circumferentially, yes? (That's just a little less intuitive.) And they curve in opposite "directions", so opposing "forces".
Tides. For example, if you look at the tides on Earth caused by the Moon, there is stretching radially but squashing laterally. Low tide is not just the ocean being at the "normal" level it would be at without the Moon there; it's the ocean being squashed by lateral tidal effects. (Of course this is all at a very heuristic level, there are lots of complications to actual tides in the Earth's oceans, but in an idealized model the effects would be what I've described.)
Note, btw, that the basic effect is the same in both Newtonian gravity and relativity. The underlying conceptual basis is very different, of course, but the actual effect is basically the same.
Yes. In units where ##G = c = 1##, the radial tidal stretching at radial coordinate ##r## in Schwarzschild spacetime goes like ##2M / r^3##, and the lateral squashing goes like ##M / r^3##. In more technical terms, these are the relevant components of the Riemann curvature tensor in an orthonormal basis.
But is it because the Moon is effectively a point?
OK, I see. Even as I try to describe the counter-example - a laterally-uniform gravitational source - I realize I'm describing a massive body that is far away, meaning its influence is effectively parallel. Which is tides.
As far as tides on Earth are concerned, yes, the Moon can be considered a point mass. There are small theoretical corrections due to its finite size, but I think they're too small to be measurable.
I'm not sure what you mean here. Tides are not the same as the "acceleration due to gravity" vector. In the Newtonian approximation you can think of them as being due to spatial differences in the magnitude and direction of that vector. (In GR that's not quite correct, but it's still a reasonable approximation for cases like the Earth and the Moon.)
A "laterally uniform" source would be one in which the magnitude and direction of the vector does not change laterally. In such a case there would be no lateral tides. If you are very far away from a spherically symmetric mass (much farther than the Earth is from the Moon), the lateral change in the vector can become too small to measure--in which case the lateral tides would also become too small to measure. But in that limit, the radial tides would also become too small to measure, because both tides are of the same order of magnitude (look at the numbers I gave previously for Schwarzschild spacetime, for example). In other words, the radial change in the vector would also be too small to measure.
Yes, this is exactly what I mean.
Yes, exactly. That's the point where I realized they were one-and-the-same. Radial tides and lateral tides go hand-in-hand. I could visualize it but I didn't have the vocabulary to express it.
Thanks!
  • · Replies 29 ·
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 31 ·
  • · Replies 22 ·
