Special Relativity: Bullets on a train
The discussion revolves around a physics homework problem involving bullets fired from a moving train and their behavior in different reference frames. The key equations used include the Lorentz transformation for time and the velocity addition formula. The participant initially struggles with the calculations but realizes that the time between shots in the train frame is affected by time dilation. After further simplification, they derive a formula for the distance traveled by a bullet in the ground frame, concluding that it is always less than the proper length of the train. The conversation highlights the complexities of applying special relativity to real-world scenarios.
six7th
A train moves at speed v. Bullets are successively fired at speed u (relative to the train) from the back of the train to the front. A new bullet is fired at the instant (as measured in the train frame) the previous bullet hits the front. In the frame of the ground, what fraction of the way along the train is a given bullet, at the instant (as measured in the ground frame) the next bullet is fired? What is the maximum number of bullets that are in flight at a given instant, in the ground frame?
Δt = γ(Δt' + vΔx'/c^2)
u = (u'+v)/(1+u'v/c^2)
In the ground frame, the time elapsed between the bullet being fired and hitting the front is given by the Lorentz transformation:
If the train has proper length l', then in the train frame Δt' = l'/u' and Δx'=l', so this gives:
Δt = γ(l'/u' + vl'/c^2)
So in the ground frame, the next bullet is fired at Δt. The distance traveled by a bullet in this time in the ground frame is therefore uΔt.
Using u = (u'+v)/(1+u'v/c^2) and Δt = γ(l'/u' + vl'/c^2)
Distance = (u'+v)/(1+u'v/c^2)*γ(l'/u' + vl'/c^2)
Now when I multiply this out I just get a huge mess that doesn't simplify into anything useful, so I feel like I'm doing this completely wrong. Could anyone give me any guidance?
Thanks
The difference between "time between shots in the train frame" and "time between shots in the ground frame" is just γΔt'. There is no additional term in the transformation, as the shooter does not move in the frame of the train - just time dilation.
You'll need the speed of the bullet in the ground frame, afterwards you can calculate everything in the ground frame and you don't have to care about relativity any more.
It's my understanding that Δx' is the distance between events in the train frame which is surely l', meaning the transformation is not simply γΔt'?
The shots always happen in the same position in the frame of the train.
Ok I see that this is true if the two events are one shot being fired and another being fired. So I now have:
Δt = γΔt' = γ\frac{l'}{u'}
The distance traveled by a bullet in the ground frame is therefore:
uΔt = uγ\frac{l'}{u'}
Using the velocity addition formula this gives
uΔt = \frac{v+u'}{1+\frac{uv}{c^2}}\frac{\gamma l'}{u'}
Now in the ground frame the train also travels vΔt, so subtracting this from uΔt will give us the actual distance of the bullet traveled in the ground frame. This gives:
\gamma^2 l\frac{v+u'}{u'+\frac{vu'^2}{c^2}} - \gamma \frac{vl'}{u'}
\gamma^2 l(\frac{v+u'}{u'+\frac{vu'^2}{c^2}} - \frac{v}{u'})
Which is much larger than l when v tends to c, which cannot be correct so I must be missing some other step.
Edit: Just realized I actually needed to simplify some more. And the \gamma^2 cancels out to give:
distance = \frac{u'^2}{u'^2+\frac{vu'^3}{c^2}}l
Which is always less than l, for all c and u.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
