Special relativity - observing spinning objects
4 replies · 4K views · last reply
Mentz114
I did a thought experiment - suppose we have a simple clock comprising a disc rotating with constant angular velocity. We can read off time inervals by counting the revs.
Another observer, passing at constant velocity will see the disc rotating at a slower rate, since moving clocks run slower.
Does this mean that all spinning objects appear to be spinning slower from another frame ?
In other words, does angular velocity transform like time in SR ?
Mentz114 said:
I did a thought experiment - suppose we have a simple clock comprising a disc rotating with constant angular velocity. We can read of time inervals by counting the revs.
Yes, I think your observation is correct.
Eugene.
Hi Eugene,
yes, it seems inevitable. It is a bit puzzling because angular velocity has dimension of reciprocal time.
I wonder if angular momentum transforms the same ?
M
Mentz114 said:
Hi Eugene,
yes, it sems inevitable. It is a bit puzzling because angular velocity has dimension of reciprocal time.
To be more precise, I think that the rotation period of a moving object should increase by the factor [itex]\gamma = (1-v^2/c^2)^{-1/2}[/itex]. Then the rotation speed of such an object should go down, i.e., the factor is [itex]\gamma^{-1}[/itex].
Eugene.
Agreed. Nothing to it. It's only a kinematic effect in any case. Thanks for the input.
