Graduate Spectral Classification Syntax for Binaries
  • Thread starter Thread starter Solkar
    Classification
The discussion focuses on the spectral classification syntax for the binary star α Cnc, specifically the notation "kA7VmF0/2III/IVSr." Participants express confusion over the use of the "/" symbol, which is typically used to separate alternative subclasses and luminosities. Clarification reveals that the notation indicates a combination of spectral classes and luminosity types, with the "/" binding only to the rightmost class or subclass. The conversation emphasizes the need to consult referenced papers for a clearer understanding of the classification. Overall, the complexity of the spectral classification system is highlighted, particularly in the context of binary stars.
Solkar
for α Cnc one gets from
http://simbad.u-strasbg.fr/simbad/sim-id?Ident=alpha+cancri
a spectral type of
kA7VmF0/2III/IVSr
I don't get behind this special use of "/" - Syntax - what's that that meant to denote?
kA7Vm+F02III xor kA7Vm+F02IVSr?
Anything else?
Astronomy news on Phys.org
I think the / is intended to separate the spectral class of the components but this one looks strange. If you look up the star here http://vizier.u-strasbg.fr/viz-bin/VizieR?-source=B/mk you will see a range of classifications.
You can follow the links to the papers the last reference has it as Am (A5/A9/F0) in the body of the paper.
I tried to follow the link to your clasification but you had to pay for access.
Regards Andrew
Yes, of course. It's generally used both for separating alternative subclasses and luminosities - "alternative" here as opposed to "between" (that would be "-").
Here however it's unclear, especially because the "A" and" "F" classification are given en suite without such any seperator.
But talking about it - maybe the tail means
one of (F0III, F2III, F0IVSr, F2IVSr)
What however combining "A" and "F" without a separator shall denote ... well...
I think your only option is to look up the reference if you want to clarify the meaning.
Regards Andrew
Yep, So more precisely, I think the only option for me is to an accessible version of the doc ...
And indeed! There indeed is one:
[RA91] Rao, S. S. & Abhyankar, K. MK morphological study of Am stars at 66 Å/mm. Journal of Astrophysics and Astronomy, Springer, 1991, 12, 133-178. doi:10.1.1.489.5030 http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.489.5030&rep=rep1&type=pdf
So by [RA91] Table. 3, Simbad's encoding
"kA7VmF0/2III/IVSr" means:
K line: A7 V
m (i.e m 39) line: F0 III
m (i.e. m 43) line: F2 III/IV
and Sr line present.
So the "/" operator binds and only binds to the rightmost class ("F") or subclass ("0", "2") token to its left.
And it's nothing about "Binaries".
Likes andrew s 1905
kA7VmF0/2III/IV Sr
I am not an astronomer. Would like a better answer.
k Spectra with interstellar absorption features
A7 Main sequence star spectral class A7
V luminosity class five
m Enhanced metal feature
F0/2 spectral classes F0 and F2
III/IV luminosity class III/IV
Sr Strontium
This could mean the strontium emission line has a signal strength equivalent to a star with luminosity class III/IV. Emission line spectra contain more than one peak so you could measure more than one spectral class. Would look purple than an A7 should look.
Then I would propose you read the paper Solkar gave the link to.
Regards Andrew
Regards Andrew
I did that before commenting.
