Spring cannon, initial velocity, and compression
7 replies · 7K views · last reply
fischelr
Part a.) You launch a 0.5 kg water balloon with a spring cannon in order to his someone 20m away. The spring in the cannon has a spring constant of 350 N/m. The spring cannon fires the balloon at a 30 degree angle with respect to the ground. What is the initial velocity necessary for the balloon to travel 20 meters?
Part b.) How much does the spring need to be compressed in order to achieve this initial velocity? Assume that 5 joules of heat is lost as the spring expands.
Fnet = Fspring - lwl = ma
sohcahtoa
*something for energy loss*
Part a.) V initial was found to be 14.09 m/s
Part b.)
First I determined the lwl parallel be 30sin 4.9=2.45N
=k[tex]\Delta[/tex]x - lwl = ma
=350 x - 2.45 = 2.45
350x = 4.90
x=.014m
x-1.4cm
I have found that the spring compression would need to be 1.4cm to launch a .5kg ball 20 meters. However, this sounds small to me. Am I missing a force on the spring? I thought about including power, but I do not have the acceleration of the ball leaving the spring.
Also, I am not sure how to subtract 5 joules of energy due to heat loss.
For part a, I did not get 14.09 m/s, can you post how you got that answer?
For part b, you could use conservation of energy here. But resultant force or 'ma' would not be 2.45 N, you'd need to find the acceleration.
On part B would it not simply be the potential energy of the spring = to the kinetic energy plus heat?
so .5(350)x^2 = .5(.5)14.09^2 + 5
x^2 = 54.6/175
x= .56 m
what equation did you use to get a velocity of 15.04? Thanks!
The better question is what did you use to get 14.09 m/s?
