Spring constant for elevator safety with maximum acceleration limit
1 reply · 3K views
Ampere
An engineer is designing a spring to be placed at the bottom of an elevator shaft. If the elevator cable should happen to break when the elevator is at a height h above the top of the spring, calculate the value of the spring constant k so that the passengers undergo an acceleration of no more than 5.0 g when brought to a rest. Let M be the total mass of the elevator and passengers.
F=-kx, Hooke's law
Energy conservation: spring energy, gravitational energy
The maximum acceleration will occur at the maximum compression of the spring, because a is proportional to x. Since kx=ma=5mg, k=5mg/x.
I then conserved energy to get 1/2kx^2 - mgx - mgh = 0.
I solved both equations to get k = 15mg/(2h). But my solution key says 12mg/h. What's wrong?
EDIT: Never mind, solved it. My force equation was off.
Well done :)
Perhaps you could show others where you went wrong with the force equation?
