Spring constant from torque on current loop in magnetic field
8 replies · 4K views · last reply
enforcer53
Consider a wire loop in a 1.88 T magnetic field (coming out of the board at a 55.0° angle). The loop is 0.300 m tall and 0.400 m wide, carrying a 2.90 A current traveling in a clockwise direction. The loop feels a torque that causes the spring to compress. If the spring is compressed by 4.30 mm, what is the spring constant?
The attempt at a solution
This is what i tried. I don't feel I am getting the right answer.
Torque is T = IABsinθ
(2.90 A)(0.120 m^2)(1.88 T)sin(55.0) =0.536
I know that Torque is also = Frsinθ
I then rearranged the formula to get F = Torque/rsinθ (0.536)/(0.15)(sin55) = 4.36 = F
I plug my Force value into the F=kx formula. In order to find k, I did (4.36)/(0.0043) which gave me k = 1013.9
This does not seem correct to me. Where did I go wrong?
Hi enforcer53,
I think we'd need to see the diagram.
Here are the diagrams
Okay. Where did you get this equation from:
If you resolve B into a component normal to the plane of the loop and a component within the plane of the loop, you will, I think, see that as far as the current-carrying-loop is concerned, only one side contributes a force which the spring can oppose.
I got the IABsinθ equation from class. I gave this problem another try.
I set it up so Kx = ILBsinθ. I rearranged to get K = ILBsinθ/x... Plug and chug (2.90)(0.400)(1.88)(sin55)/(0.0043) = 415.4
Am I getting closer?
The dimensions of the loop are 0.400 and 0.300. So I used the length of 0.400
Why did you decide on 0.400?
Ah, but what is the length of the side of the current in which we are concerned with in opposing the spring?
