Calculating Work and Energy in a Spring Loaded Cannon
  • Thread starter Thread starter stripes
    Cannon Spring
The discussion centers on calculating work and energy in a spring-loaded cannon involving a football. The initial calculations for work done by the spring were incorrect due to misunderstanding that the spring force is not constant and requires integration to find the work done, resulting in 50 joules. The participants clarified that the work done on the football can be equated to the change in kinetic energy, using the formula for elastic potential energy of the spring. The correct approach involves recognizing the elastic energy transformation into kinetic energy and applying it to find the football's speed and distance traveled before stopping due to friction. The conversation emphasizes the importance of understanding energy concepts in solving physics problems accurately.
stripes
A football with a mass of 0.40 kg is placed into a spring loaded cannon with k = 400 N/m. The spring is compressed by 50.0 cm. a.) find the work done on the football by the spring as the football moves from the compressed position to its equilibrium position. The cannon is aimed horizontally along the icy grass of a football field. b.) Find the speed of the football when the spring is at its equilibrium position. The cannon is aimed horizontally along the icy grass of the football field. If the coefficient of kinetic friction between the football and the icy grass is 0.080, c.) how far down the field will the football slide before coming to a stop?
F = kx (for a spring)
W = Fd
Fnet = ma
v^2 - (v initial)^2 = 2ax
a.) F = kx (for a spring)
F = (500 N/m)(.500 m)
F = .250 N
W = Fd
W = (.250 N)(.500 m)
W = .125 J
This was marked wrong...where did I make my mistake?
b.) Fnet = ma
Fspring = ma
a = Fspring/m
a = (.250 N)/(.40 kg)
a = .625 m/s^2
v = sqrt(2ax + (v initial)^2)
v = sqrt(2(.625 m/s^2)(.500 m) + (0 m/s))
v = .79 m/s
This was wrong...
c.) Fnet = ma
Fspring - uFn = ma <<< uFn is force of friction, u is coefficient of kinetic friction, Fn is normal force.
Fspring - u(mg) = ma
a = (Fspring - u(mg))/m
a = (.250 N - (.080)(.40 kg)(9.81 m/s^2))/(.40 kg)
a = -.1598 m/s^2 <<< so the football is decelerating as it goes down the icy football field.
x = (v^2 - (v initial)^2)/2a
x = (0^2 - (.79 m/s)^2)/2(-.1598 m/s^2) <<< info from above and part (b)
x = 1.95 meters
This was also marked wrong...
I'm not quite understanding why this method of solving is incorrect...
Thanks so much for your help in advance!
"W = Fd
W = .125 J
This was marked wrong...where did I make my mistake?"
The force of the spring is not constant. It is proportional to the compression, so it decreases linearly while the deviation from equilibrium changes from 0.50 meter to zero. How do you get the work? Moreover, the spring constant is not 500 N/m.
ehild
lol, i just realized that k = 400 N/m, and (400 N/m)(.500 m) is 100 N...though this isn't really important. We see that because force is not constant, we must take the area under the curve, that is, the definite integral, of this force equation Fspring = 400x on the interval 0 to .500 m. Doing so gives you 200x^2 from 0 to .500, which gives you 50 joules...so the work done over that change in x is 50 joules, correct?
From there, is it safe to say I can use the same methods I did above to solve for (b) and (c)?
Of course, you can apply this method for question b. You know the work done on the ball; this work will be equal to the change of the kinetic energy according to the work-energy theorem.
Or you can think in terms of energy. The spring did work on the ball on the account of its elastic energy - but it is equal to the work which was needed to compress the spring. Some times before, the spring was compressed, work of 1/2 k x^2 was done and that work gave the spring so much energy.When the spring is released, this elastic energy transforms into other kind of energy, for example, the kinetic energy of the ball. You can use this formula E(spring)= 1/2 kx^2 whenever a compressed spring is concerned.
You determine v from the kinetic energy of the ball. With this initial velocity, the ball moves with constant deceleration under the effect of friction. When will it stop?
ehild
ahhh...kinetic energy of a spring...should have thought of that, would have saved me a lot of trouble. Either way, the question has been handed in, and we'll see how it turns out!
Thanks so much ehild for the help!
it is elastic energy of the spring, not kinetic. :smile:
  • · Replies 21 ·
