Spring Scale Problem: Finding Time w/ Force & Mass
  • Thread starter Thread starter DrDanger
    Scale Spring
1 reply · 2K views
DrDanger
You use a spring scale to pull a 1.5 kg object on a horizontal frictionless surface with a constant horizontal force of 1.3 N (according to the scale reading). You use a stopwatch to time how long it takes the object, starting from rest, to cover a distance of 2.7 m. What is the reading of the stopwatch?
F=-KX
F=ma
[tex]\Delta X=volt+.5aT^2[/tex]
So I did a=F/m to get the acceleration then plugged that into [tex]\Delta[/tex] X=volt+.5aT^2 and Vo is equal to 0. After i plugged it all in I got 2.49, is that right? For some reason it seems wrong.
On a side note, is possible to find k using f=kx?
