SQL commands with subtraction and multiplication
35 replies · 4K views · last reply
mathmari
MHB
Hey! :giggle:
The following relations of a project administration of a company are given, where the primary key of the respective relations are underlined.
Three relational schema definitions in plain text: mitarb(mnr, name, vorname, kompetenz, kompbez, tagessatz), projekte(projnr, projektbez, kundennr, volumen), and projektzuord(projnr, mitarbnr, kompetenz, datumvon, datumbis), with primary key attributes underlined.
An employee can be assigned to several projects. Furthermore, an employee can have different competencies, which are billed at different daily rates. Each employee can do a task only on a daily basis. The assignment of employees to projects is contained in the relationship projektzuord. The relations mitarb und projekte contain the master data for the existing employees and projects.
Table titled projekte with columns projnr, projektbez, kundennr and volumen, listing five rows: p1 Bestandsoptimierung kn13 150000; p2 Absatzplanung kn13 100000; p3 E-Controlling kn13 150000; p17 Lagerreorganisation kn19 250000; p19 Facilitymanagement kn7 120000.
Database table named mitarb with columns mnr, name, vorname, kompetenz, kompbez and tagessatz, listing seven rows of employee competency data.
Table titled projektzuord with columns projnr, mitarbnr, kompetenz, datumvon and datumbis, listing eight project assignments from p1, p3 and p17 with dates in 2022.
In order to solve the tasks in the following, enter general SQL statements. The commands of the task should be as generally as possible, i.e. they should also be applicable to other data of the same form. Hint: You can calculate with the data type DATE like with an INTEGER
1) Which different employees (first name and last name) are assigned to the project with the name Lagerreorganisation ?
2) Which different employees (first name and last name) generate the most sales? Give a sorted list. The turnover is calculated from the number of planned days multiplied by the daily rate.
3) Which competencies (designation of competency) will be needed at least twice in the planned projects ?
4) How many employees with which skills are available in the period from 03/15/2022 to 04/09/2022, that is, not assigned to other projects?
5) There is a new project p42 called Datenreorganisation of customer kn99 and a Volume of 12000 euros. The employee Maier will be responsible for this new project from 01/03/2022 to 31/05/2022. Give SQL commands to update the database.
I have done the following :1)
SELECT DISTINCT m.vorname, m.name
FROM mitarb m, projektzuord z
WHERE m.mnr = z.mitarbnr AND z.projnr = 'p17'Is that correct ? :unsure:2)
SELECT m.vorname, m.name, MAX(DATEDIFF(day, z.datumbis, z.datumvon) * m.tagesastz)
WHERE m.mnr = z.mitarbnr AND m.kompetenz = z.kompetenzIs that the correct way to check the employees with the most sales? :unsure:
At (3) I have done :
SELECT p.projektbez
FROM projektzuord z, projekte p
GROUP BY p.projektbez, p.projnr
HAVING COUNT(p.projektbez)>=2 AND p.projnr = ANY (SELECT z.projnr FROM projektzuord z)I think it is correct! :unsure:
At (4) I have done :
SELECT COUNT(m.mnr), m.kompetenz
FROM projektzuord z, mitarb m
WHERE ((z.datumbis < '20220315' OR z.datumvon > '20220409') AND (m.mnr = z.mitarbnr)) OR m.mnr != ALL (SELECT z.mitarbnr FROM projektzuord z)
GROUP BY m.mnr, m.kompetenzI don't get a result. Is that correct, i.e. in this period there is not available emplyee, is there? :unsure:
At (2) I have done :
SELECT m.vorname, m.name, MAX(DATEDIFF(day, z.datumbis, z.datumvon)*m.tagessatz)
GROUP BY m.vorname, m.name
ORDER BY MAX(DATEDIFF(day, z.datumbis, z.datumvon)*m.tagessatz) But "DATEDIFF" is not working. How do we use that corrctly ? :unsure:
Hey mathmari!
You have matched the employee on the column "mnr", but that is not a primary key is it?
That is, it does not uniquely identify an employee. (Worried)
Furthermore, it "should also be applicable to other data of the same form".
Suppose we want want to use it for "Facilitymanagement" instead of "Lagerreorganisation", then the query won't work, will it? (Worried)
"mnr" is a primary kry for mitarb, it is underlined. :unsure:
This one was also unclear to me. What does this mean that it should be also be applicable to other data of the same form? How can it be general ? :unsure:
There is only one primary key in a table, which is a combination of 1 or more columns. 🧐
In this case the primary key should consist of the combination of mnr and kompetenz.
To be fair, it does look a bit strange that they made kompetenz part of the primary key, but that is what it says.
Consider the table projectzuord. It has projnr underlined, but that is not a primary key on its own is it?
Any projnr will definitely be duplicated in multiple rows as there will usually be more than 1 employee that is assigned to a project. 🤔
The question has a desired output, and a given input.
The given input is "Lagerreorganisation". To make it applicable to other data of the same form, we should be able to replace 'Lagerreorganisation' by some other project name and then the query should still give the desired output. Since you have hardcoded the projnr 'p17', that won't work. 🤔
How do we give that "Lagerreorganisation" as input ? Do we set a variable equal to that befor we write SELECT ? :unsure:
There are multiple ways to do it.
If I'm not mistaken, we can use a nested select in the WHERE clause. Or a nested select in the FROM clause. Or a WITH clause. Or we can use a VIEW that we create beforehand. Or instead, we can also just use another table in the query. 🤔
You mean to write WHERE "Lagerreorganisation" is from the given table? Or how do you mean that? I haven't really understood that. :unsure:
So do you mean it as follows ?
FROM mitarb m, projektzuord z, projekte p
WHERE m.mnr = z.mitarbnr AND p.projektbez = (SELECT p.projektbez FROM projekte p WHERE p.projektbez = 'Lagerreorganisation' ) AND p.projnr = z.projnr :unsure:
Did you check if it works? 🤔
Either way, I think it should be:
WHERE m.mnr = z.mitarbnr AND z.projnr IN (SELECT p.projnr FROM projekte p WHERE p.projektbez = 'Lagerreorganisation' )
That is, we don't need `projekte p` in the FROM clause, and we don't need to refer to it in the WHERE clause either.
I've also changed the "=" into "IN" since the result of the sub query is a set. 🤔Btw, alternatively we can also do:
WHERE m.mnr = z.mitarbnr AND p.projnr = z.projnr AND p.projektbez = 'Lagerreorganisation'
can't we? 🤔
Yes, I got the correct result, the same with the result I get with your commands! :geek:
can't we? 🤔
I see ! 🤩
At (2) I have written the below commands :
I get an error because of the DATEDIFF but in Google I found that it is defined like that. What am I writing wrong? And is the idea in ngeneral of that commands correct ? Do we have to use also here some nested WHERE ? :unsure:
ORDER BY MAX(DATEDIFF(day, z.datumbis, z.datumvon)*m.tagessatz)I get an error because of the DATEDIFF but in Google I found that it is defined like that. What am I writing wrong? And is the idea in ngeneral of that commands correct ? Do we have to use also here some nested WHERE ?
What is the error that you get? 🤔
I think DATEDIFF will work, but we're not using it right. We shouldn't take a MAX of it. Instead we should list for each employee what their turnover is, give the column a name (for instance "AS turnover"), and sort on that name in the ORDER clause in descending order. 🤔
I get an error about "day" : no such column: day. :unsure:
What do you get if you run:
SELECT DATEDIFF(day, '2011-08-25', '2017-08-25') AS DateDiff;
The same error as previously. :unsure:
Which SQL are you using? 🤔
I use this one . So is it because of the compiler or am I doing something wrong? :unsure:
Yes.
I found that we get that error if we try to use PostgreSQL.
In its manual I found that we can use for instance:
SELECT DATE_PART('day', '2011-12-31 01:00:00'::timestamp - '2011-12-29 23:00:00'::timestamp);
instead. 🤔
Alternatively we can use a different SQL compiler.
If we pick:
Dropdown menu opened from the button labelled MS SQL Server 2017, listing MySQL 5.6, Oracle 11g R2, PostgreSQL 9.6, PostgreSQL 9.3, SQLite (WebSQL), SQLite (SQL.js), and MS SQL Server 2017, which is highlighted.
then it works for me. 🤔
Do we not do that as follows ?
SELECT m.vorname, m.name, DATEDIFF(day, z.datumbis, z.datumvon)*m.tagessatz
ORDER BY MAX(DATEDIFF(day, z.datumbis, z.datumvon)*m.tagessatz) I get the error : " Column 'projektzuord.datumbis' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause. "
:unsure:
That's because you have GROUP BY and ORDER BY clauses that have certain requirements. If we leave out those clauses, it works just fine. 🤔
So is the following correct ?
SELECT m.vorname, m.name, DATEDIFF(day, z.datumvon, z.datumbis)*m.tagessatz
WHERE m.mnr = z.mitarbnr AND m.kompetenz = z.kompetenzDo we just have to order the list that we get? :unsure:
If I run that, then I get:
Table with three columns headed vorname, name and an empty header; rows list Armin Müller 32000, Armin Müller 38400, Felicitas Wagner 78000, Dietmar Kaiser 54600, and a partly visible Dietmar Kaiser 40600.
I see a couple of problems:
1. Armin shows up twice.
2. The 3rd column doesn't have a header.
3. The table doesn't have the employee with the biggest sales at the top.
(Worried)
3. The 3rd column has negative numbers.
(Worried)
I corrected the problems 2 and 3. Do we not solve the first problem with DISTINCT ?
I have now this but I get again Armin several times. :unsure:
Armin can work both as a programmer and as a system administrator and he gets paid different rates for those roles.
I think we have to combine them somehow. 🤔
Do we do that with GROUP BY ? :unsure:
Yes. 🤔
Do we not write that as follows ?
SELECT DISTINCT m.vorname, m.name, DATEDIFF(day, z.datumvon, z.datumbis)*m.tagessatz AS Umsatz
GROUP BY m.vorname, m.name Because I get the error :
Column 'projektzuord.datumvon' is invalid in the select list because it is not contained in either an aggregate function or the GROUP BY clause.
:unsure:
We are trying to group the 2 rows that refer to Armin into 1 row.
Those 2 rows have different numbers for the Umsatz.
How should those 2 numbers be combined (aka aggregated)? 🤔
