What is the role of surface interactions in the stability of microemulsions?
The stability of microemulsions is primarily attributed to the stronger interactions between molecules at the liquid interphase and the emulsifier compared to those in the bulk of the liquid droplet. This phenomenon is similar to how liquids spread on solid surfaces without forming a contact angle. Microemulsions, characterized by small micelles that repel each other due to high surface charge, remain thermodynamically stable and appear clear, allowing for image distortion when viewed through them. Unlike ordinary emulsions, microemulsions do not separate the non-polar fraction from the aqueous phase due to their unique structural properties.
  • Understanding of microemulsion and emulsion concepts
  • Knowledge of molecular interactions at liquid interfaces
  • Familiarity with micelle formation and properties
  • Basic principles of thermodynamics related to stability
  • Research the role of surface tension in microemulsion stability
  • Explore the properties of different emulsifiers used in microemulsions
  • Investigate the thermodynamic principles governing liquid-liquid dispersions
  • Learn about the techniques for characterizing microemulsions, such as dynamic light scattering
Chemists, materials scientists, and engineers involved in formulation science, particularly those working with emulsions and microemulsions in various applications.
Dario56
Unlike emulsions, microemulsions are thermodynamically stable. Its stability is often explained by entropy changes brought about by dispersing liquid in another liquid, however this can't be the whole story behind its stability since dispersing liquids also happens in regular emulsions and they aren't stable thermodynamically.
I am not sure if I am correct, but I think that stability of microemulsions is due to the interactions between molecules on liquid interphase and emulsifier being better (stronger) than between molecules in the bulk of the liquid droplet in similar way when liquid spreads on the surface of the solid forming no contact angle with the surface. If interactions between emulsifier and surface molecules are more favourable than surface molecules have lower potential energy compared to the bulk and there is tendency to increase surface area between molecules and emulsifier or in other words there is tendency to create emulsion.
I wasn't able to find this explanation anywhere online though, but I think it has sense. What are your thoughts?
Chemistry news on Phys.org
Emulsions form when a non-polar liquid is encapsulated by an "emulsifier" which is typically a molecule such as soap that has a non-polar end (usually a hydrocarbon) and a polar end that can be a carboxylate or ammonium salt.
These encapsulations are called micelles and are dispersed in water which is the continuous phase. In ordinary emulsions, these micelles are large and can merge thus separating the non-polar fraction from the aqueous phase. In microemulsions the micelles are small and the surface charge is sufficiently high that they repel each other.
Typically, the micelles are small enough that they do not disperse light as ordinary emulsions and thus appear clear. Microemulsions can be distinguished from solutions by looking at print through the liquid. Microemulsions will display some distortion of the image whereas solutions will not.
  • · Replies 21 ·
