Stack poker chips in a staircase-like fashion
  • Thread starter bigdave
In summary, cesiumfrog's post provides a more detailed explanation of the situation than what was provided in the original post.
bigdave
k so I have a bet going with one of my friends, and here's the deal.
If you stack poker chips in a staircase-like fashion, let's say going left to right like this:
____0000
___0000_
__0000__
_0000___
0000____
I say that you can't get to the point where the top poker chips left-edge is further right than the bottom chips right edge. My friend says that the chips can go infinitely far in the right direction if you have enough of them. Are either of us right? an explanation would be great to... thanks!
Well, you can't go on for infinity, that's for sure, hypothetically speaking.
Not thinking of the low friction which will make it fall very soon, the weight of the chips on one side will make the lowest chip tip over. With the low friction, the other chips will glide away soon. I don't have the mathematics, but i think my explanation is correct.
Look at it as a tower that is not attached to the ground, tilting in one direction. If you build it tall enough it will eventually fall. The same principle goes for stacking pokerchips. Just that the chip over the lowest chip will glide from the lowest chip way before the "tower" will fall because of the weight concentrated on the side of the chip not being backed up by any chip.
No, you can't go infinitely far to the right. At some point it is going to tip over.
What if we assume the stacking will have a hyperbolic shape?
NO! No matter what, NO! Just do a force balance and you can find out how many chips you can stack.
The diagram seems to indicate that they're being stacked on edge, so I don't think you'll even get two layers. :tongue:
You can go infinitely far, if you stack them in a particular shape.
If you stack them at an angle in a linear fashion, they tip over when the center of the middle chip is outside the footprint of the bottom chip. The center of the middle chip is the center of gravity and it must always be above the footprint of the tower for the tower to be stable.
The OP's friend is correct.
This is an old problem, and the answer is that with an unlimited number of chips you can make the topmost chip go as far to the right as you wish (infinite overhang is possible). With n chips, simply displace the k'th chip from the top by d/2k to the right of the chip below it (d is the chip diameter). The harmonic series [itex]\sum _k (d/2k) [/itex] goes to infinity as k increases indefinitely, and the CoM of any subpile (from the top) is clearly above (divide above sum by number of chips and then take limit of large n) the topmost brick below that subpile.
1] Are you saying you can do this with the configuration as shown in the OP's post?
2] Judging by past experience you're presumably not insane, so presumably #1 is not true, so can you please demonstrate the configuration you ARE talking about?
It sounds to me like you're going to get a curved stack of chips that asymptotically appproaches vertical. However, you are wrong in your conclusion. It will not extend infinitely far to the right. It will not exceed d to the right.
Yes, with the configuration shown in the OP's figure, except that instead of constant spacing (as seems to be depicted), the spacings are as described in my post above.
It'll be easier if I just find a link...give me a minute.
Edit: There's one in post#8 by cesiumfrog. Here's another one: http://www.cs.tau.ac.il/~zwick/papers/overhang-SODA.pdf
To find more hits google maximum overhang bricks.
Hahah, wow. I stand corrected. I never knew so much work went into stacking bricks. :tongue2:
Gokul, the PDF does NOT demonstrate the OP's configuration. They all use counterbalances. Total cheating! Cesiumfrog's is the mathematical explanation, but does not adequately demonstrate the result.
I found this: http://oak.ucc.nau.edu/jws8/classes/137.2006.1/index.html
And this: http://oak.ucc.nau.edu/jws8/classes/137.2006.1/images/overhang31blocks.gif
But, not being satisifed with theory, I had to prove it...
And tie-me-up-with-electrical-tape-pass-current-through-my-body-and-call-me-wiggly it really can be done! (see attachment)
I'd like to see this done with something more precise than Lego bricks - which are flawed enough to limit the maximum amount of stacking (you can see how the top bricks are not horizontal).
Yes, it does. If you can't see it there, then all the demonstration required is in my post (two up from this one).
They do not ALL use counterbalances. The description of the classical (harmonic) solution (devoid of counterbalances) is given in the first paragraph of the linked pdf, and the picture is the background configuration on figure 1.
I didn't read everything on that link, but there's a full mathematical proof in my post too (only missing some steps). To see the proof that the CoM of any pile of chips above a given chip lies over that chip, all you need to do is show that [itex](1/N)\sum_k (1/2k) < 1/2 [/itex]. This follows trivially that each term is bounded above by 1/2.
I have no idea what you mean by this!
I've done it with a stack of CDs. They're much flatter and more parallelized.
Is it just me or does weight, surface texture (friction), and the shape of the object matter? I wonder if there is a formula to treat all these at once.
It is just you! :biggrin:
The only requirement on the shape imposed by the problem is that the top and bottom surfaces be parallel, and all chips be identical. An infinite overhang can be achieved independent of weight, surface texture or other aspects of the shape than those specified above.
reference please
reference please
Reference to what? There are multiple links to proofs scattered about this thread. Have you read them?
I am saying that, while there is a description, and even a proof, there isn't a demonstration i.e. visual.
Yes, there it is. How delightfully obfuscatory.
I can doubt a claim of a proof faster than I can doubt a physical demonstration.
Why? https://www.physicsforums.com/showpost.php?p=179681&postcount=50". :wink:
...which is why ... I had to see it done for real.
That would be cool. How high did you have to stack it?
Actually, it's not dependent on the object used is it? I should be able to simulate any of those configs listed in the reference I added:
4 blocks (the first with overhang > L = length of one block).
11 blocks (the first with overhang > 1.5 L).
31 blocks (the first with overhang > 2 L).
83 blocks (the first with overhang > 2.5 L).
reference please
Because in any of the proofs, none of those things are variables. They are immaterial to the problem/solution. In fact, the dimensions of the blocks aren't a factor either, as I just realized in my previous post.
It wasn't nearly optimal (measurement limitations, time limitations), and I think it took me like 45 CDs to get an overhang of a little over 2L. With CDs you need to be careful about having a level and flat surface to build on.
Cool. And totally non-intuitive.
According to the paper I linked to, you could have done 2L with a mere 31 CDs. A mere 11 gets you an overhang of 1.5L.
This would make a great bar bet.
It doesn't look to me like that stacking configuration is the same as with the OP. I see what you do - by overloading the bottom, you can make the top of the stack go further to the right without moving the center of gravity outside the footprint of the bottom chip. Clever, but the OP shows a linear stack.
I don't believe the linearity was intended in the depiction. After all, this is a well-known puzzle (it's called the overhang problem) that's quite old and does the rounds every now and again. Moreover, the OP could only have depicted the correct configuration if he knew the solution (so naturally, any details in his depiction other than the broad idea must be ignored).
1] The lower part of the stacks are, for all intents and purposes, linear.
I don't think we can read too much into the OP's drawing.
2] Actually, I'm not sure this wouldn't work as a linear stack. Can anyone think of a reason why it wouldn't? The overhang would be less, but it should still work. It would just need to be taller.
Hey thanks to all, just for the record there was no condition made that said the stack had to be linear, so I lost the bet (the only reason why i made the diagram linear was because that was the only way i could think of to do it).
But I still don't think it can be done as a linear stack.
If you placed the chips like this you could have built a tower of chips with an infinite length:
___000_
__000__
_000___
__000__
___000_
__000__
_000___
__000__
___000_
__000__
:P
The key to the solution is that the center of gravity is never outside the footprint of the bottom piece. If the stack is linear, it eventually would get outside and fall over.
Fair enough, but you still might be able to argue your way out of it by saying it isn't really a staircase-like fashion (your words in the OP) if done using Gokul's solution. :wink:
  • #31
The maximum overhang with a linear stack will be L, irrespective of the number of chips in the stack. Again, it follows directly from writing the coordinates for the CoM.
  • #32
Right. Of course. The lower section must overbalance what's above it.
  • #33
I managed to get L=~1.75 with about 21 CDs. That was about the limit for me. Believe it or not, CDs are not parallel enough. They have a tiny ridge around the core that messes everything up. You can see in the pic how the top ones are leaning markedly.
  • #34
Now I think about it, mine were leaning too, but I chalked that up to the low stiffness rather than nonparallelism (I didn't inspect very carefully, I guess - I was in a bit of a hurry). I'd imagined that if the CD stack were a contiguous structure with the stiffness of the CD-plastic, it would still droop some under the weight, but I think you're right - it's the little rigdes round the inside. I used an essentially vertical stack of something like 15-20 CDs before I made noticeable shifts.
  • #35
CD's aren't quite flat, either - the center section has a raised rim around it. Cool pic, though, Dave.
1. How many chips do I need to stack in a staircase-like fashion?
The number of chips needed depends on the height and width of the staircase. Generally, you will need more chips for a taller and wider staircase.
2. What is the best way to stack the chips?
The best way to stack the chips is to start with a stable base of chips and then stack smaller numbers of chips on top, gradually decreasing the number of chips as you move up the staircase. This will create a sturdy and visually appealing structure.
3. Can any type of poker chips be used for this staircase?
Yes, any type of poker chips can be used as long as they are the same size and shape. Mixing different types of chips may result in an unstable structure.
4. How do I prevent the chips from falling over?
To prevent the chips from falling over, make sure to stack them evenly and use a gentle touch when stacking. You can also use a ruler or other flat object to help guide the chips into place.
5. Is there a limit to how high I can stack the chips?
The limit to how high you can stack the chips depends on the stability of your base and the type of surface you are stacking them on. It is recommended to not stack the chips higher than 10-12 inches to prevent them from toppling over.
  • Set Theory, Logic, Probability, Statistics
  • Mechanical Engineering
  • General Math
  • High Energy, Nuclear, Particle Physics
  • Other Physics Topics
  • General Discussion
