Stacking bricks-Physics puzzle
  • Context: Undergrad
  • Thread starter Thread starter Andreas C
    Puzzle
The discussion revolves around a physics puzzle involving stacking indestructible bricks measuring 10cm in length and 4cm in height. Participants explore the maximum distance the edge of the last brick can extend from the center of the first brick without causing the structure to collapse. The second part of the puzzle introduces an arc formation, where the challenge is to determine the maximum distance of a brick from a line drawn between the bottom and top bricks. Key insights include the conclusion that the maximum distance from the line is nearly half a brick length, particularly during the transition step when changing stacking direction.
  • Understanding of basic physics principles related to stability and balance
  • Familiarity with geometric concepts, particularly in relation to stacking and angles
  • Knowledge of limits and convergence in mathematical sequences
  • Experience with problem-solving in physics puzzles or engineering challenges
  • Research the principles of stability in stacked structures
  • Explore geometric series and their applications in physics
  • Learn about the mechanics of equilibrium and forces in static systems
  • Investigate similar physics puzzles and their solutions for deeper understanding
This discussion is beneficial for physics enthusiasts, educators, students tackling physics puzzles, and anyone interested in the mechanics of stability in structures.
Andreas C
Part 1:
You have an unlimited supply of indestructible bricks that are 10cm long and 4cm high. After some thougt, you realize that building a huge wall to keep immigrants out is a dumb idea, you decide to do something more creative with them. Since sticking things together, reinforcing structures and using concrete are all techniques foreign to you, you decide to put one brick on the ground, put another one on top of if, then another one on top of that, etc. How far to the right can you get the edge of the last brick from the center of the first one without making the whole structure colapse?
Part 2
You now decide to make a sort of an arc. You start stacking bricks leaning towards the right, and then you stop and start stacking them towards the left, until the center of the last brick is over the center of the first brick. If you draw a line from the bottom brick to the top brick in this structure, what can the maximum distance of a brick from that line be?
Mathematics news on Phys.org
Andreas C said:
Part 1:
Part 2
If this is homework, please repost to the homework->precalc forum.
That is not homework, that is a puzzle intended to be solved by the members of this forum! If you know the answer, feel free to post it, but with a spoiler, so that others can solve it themselves!
Oh, ok. The first part is very well known, so I won't post a solution to that.
For part 2, I offer an answer to a different question.
The number of bricks in the lower section, heading to the right, is roughly the square of the number of bricks in the upper section.
That counts as an answer I guess. Can anyone prove this conclusion?
Single-sided stack: brick n from the top can be 1/(2n) brick lengths ahead of brick n+1 to stay in balance, that is the optimal strategy. The harmonic series diverges, therefore arbitrary overhead length can be reached, but the number of bricks needed is about n = e2x up to a numerical prefactor, where x is the overhang length in multiples of the brick length. Note that doubling x means squaring n.
Two-sided: The top stack is like the single-sided stack, at the transition region we can go back by nearly one brick length in one step, afterwards we are stuck in the same pattern again. Neglecting this one brick length, we get the same situation as for the single-sided stack, where the bottom part doubles x and therefore squares the number of total blocks. For large n we can approximate n(n-1) as n2.
Good answer, but did you mean "nearly half a brick length" instead of "nearly one brick length"? You can't really go more than half a brick length, unless of course you mean precisely AT the transitional step...
Yes, I mean the transition step: the first in the opposite direction, as seen from the top. We can go backwards by 1 - 1/(2n) where n is the number of bricks that were stacked in one direction.
  • · Replies 84 ·
