Solving Standing Waves Problem: Why Nodes at Multiples of 3 Remain Unexcited
The discussion centers on the phenomenon of standing waves in a string fixed at both ends, specifically addressing why nodes at multiples of three remain unexcited when the string is plucked at L/3. The mathematical relationship mL = nλ is explored, indicating that only wavelengths that are multiples of three can arise from this plucking point. Participants emphasize the importance of understanding how the shape of the wave, such as a skewed triangle, is influenced by the placement of nodes and antinodes. The conversation also touches on the necessity of plucking the string at points that do not coincide with the nodes of overtones to excite those frequencies. Overall, the thread highlights the complex interplay between wave behavior, mathematical modeling, and physical principles in string dynamics.
negation
I'm unclear about the entire idea of why if a string fixed at 2 ends is plucked at a point, say L/3 from the left, the node at the pluck point and any node that is a multiple integer of 3 would be unexcited.
Trying to see it mathematically, and I've only been able to arrive at is this.
mL=nλ
At (1)(L/3), we have L/3 = 3λ
At (2)(L/3), we have 2L/3 = 6λ
and so on.
So, if the string is plucked at L/3, the only wave length that can be arised on the string are n-multiplers of λ.
3λ, 6λ, 9λ...etc.
The standing wave is going to be a skewed triangle in form right?
Why not sketch out the triangle, then sketch out the next dozen harmonics under it.
Which harmonics will help sum up to the triangle shape?
Clearly anything with an antinode close to the peak of the triangle right?
But anything with a node where the triangle apex has to go will make the sum sort-of dip there and you don't want that.
Put another way:
If you added up the multiples-of-3 harmonics, what shape do you get?
If you simply pluck a string anywhere but the centre, I think you will not eliminate any of the overtones. You will, of course, alter the spectrum of the sound. You need to partially stop the string and force a node (as when you sound a 'harmonic' on a guitar) - hence eliminate a number of overtones plus the fundamental. Another way to doctor the sound would be to pluck in two places simultaneously. That could eliminate some of the overtones.
Put another way:
Hi Simon,
I've seen something like that on a website but unable to wrap my head around still.
Do you think a mathematical reasoning could be shown?
If you pluck on a overtone's node, that overtone is not excited.
The string can only vibrate in its normal modes and these are found by the discrete Fourier Transform of the shape of the string when released. It is only when the triangle has its apex half way along that there are no even terms, afair.
This is quite a good link about the topic. I found a couple of other links by my Java wouldn't allow them to run.
Oh yes. You are right about that.
sophiecentaur's link should work for that.
But you should be able to do it yourself - any shape wave can be constructed by a sum of sine waves. It's called a Fourier transform.
You know how to do addition already.
But you should be able to visualize it -
Consider the opposite: say youwant to excite the second overtone.
The third overtone has a node at L/3. That means that this point on the string is not allowed to move all that much (if it moves a lot then, by definition, it is not a node).
The point that you pluck the string is the point that moves the most.
Therefore - to excite the 2nd overtone, you cannot pluck the string at x=L/3.
Therefore, plucking the string at x=L/3 cannot excite the 2nd overtone - or, by extension, any overtone with a node at x=L/3.
Like I said - draw it out, and do some adding up.
Remember, it would be a Discrete Fourier Transform because it is not from -∞ to ∞. This is why there are discrete wavelengths associated with it and not a continuum.
For standing waves there are 2 equations: mλ/2 and (m+1/2)λ. Are they different?(they shouldn't be!) and when is one used over the next? Can someone show a derivation that explicitly shows the relationship between the first and second?
The boundary conditions dictate whether you get a node (closed end on a pipe) or an anti node ( open end). That governs how many half waves there will be.
Beware:- what you have written are not equations. Equations have an equals-sign in them.
mλ/2 = (m+1/2)λ when m=-1.
But in context I think you mean the conditions for standing waves of the mth overtone.
(1) L=mλ/2
(2) L=(m+1/2)λ
... m=0,1,2,3...
If so then these are different conditions, and apply to different situations.
Why not?
... and when is one used over the next?
Determined by the boundary conditions.
The second one is for one end free to move
The first is for both end free or both ends fixed.
There is a third situation, where the "wire" forms a loop.
You are assuming here that the two equations say the same thing, but they do not. So there is no derivation that will do that.
You can easily find derivations and examples online in any page devoted to standing waves.
  • · Replies 19 ·
9K
19K
