nomadreid said:
Any comment on my example that multiplication by a complex number would seem to add a rotation, thereby changing the vector? If not, I am sure I will get to it as I work through the book.
Good pick up.
Indeed it is - its just states are invariant to it.
This is an interesting symmetry and is an example of a gauge symmetry - specifically its U(1) symmetry. In fact, and I won't explain it yet - you really need to internalise a few things before I let the cat out of the bag - its actually one of the rock bottom foundations of QM - but just to whet you appetite a bit check out:
http://www.colorado.edu/philosophy/vstenger/nothing.html
I could detail it now, and I have posted about it in the past - but it's really utterly trivial unless you have your thinking cap on a bit to see what's going on. People would basically comment - first they don't get it - then so? That's the problem with this view of physics - you hear it all the time but unless you are alert to it its importance it escapes attention:
https://www.amazon.com/dp/0918024161/?tag=pfamazon01-20
'Although simply written, this is not a book for beginers. On the other hand it doesn't hurt to read it early and think about it for a long time, rereading it from time to time, in order finally to get the main point. Wigner points out that the basis for answering the question posed by him, 'Why is it possible to discover laws of nature?' is explained in every elementary physics text but the point is too subtle, is therefore lost on nearly every reader. The answer, he explains convincingly, lies in invariance principles. As an example, were local Galilean invariance not true it would have been impossible for Galileo to have discovered any law of motion at all. The same holds for local translational, rotational and time-translational invariance. Inherent in Wigner's argument is the explanation why the so-called principle of general covariance is not the foundation of general relativity, which also is grounded in the local invariance principles of special relativity.'
A deep analysis of fields such as the EM field shows that gauge symmetry is its deep explanation - in fact U(1) symmetry is what's responsible for EM:
http://quantummechanics.ucsd.edu/ph130a/130_notes/node296.html
Strange but true.
Now you are getting to the deep, the really deep, revelations modern physics has told us about the world:
http://www.pnas.org/content/93/25/14256.full
Once you fully internalise it you will sit there stunned.
Philosophers always want to sit around arguing what exactly is reality (yawn - they get nowhere - its a wordfest) - what at rock bottom is it really. They get nowhere of course because you always must double check your speculations by asking nature if its true - that's called doing experiments - which is basically what science is about. Quietly, without fan fare physicists and mathematicians have figured it out.
It should be more widely known. Me telling you about it however will not actually replace you experiencing it yourself - which I invite you to do.
Start out with Noether's Theorem:
http://www.physics.ucla.edu/~cwp/articles/noether.asg/noether.html
Thanks
Bill
