Statics and equilibrium - asking for some guidance
Finn J
Thread moved from the technical forums, so no Homework Template is shown
Hi,
I'm not used to communicate physics in English, so my language may be a bit off.
This task is fairly simplistic. It's a figure which is held up in points A and B (both having an x and y force exerted on them), and the figure has a joint C. It is depicted in attached files.
The answers are supposed to be F_A = 13,00 kN, F_B = 7,85 kN, F_C = 9,88 kN.
My results are erroneous.
Can anyone please give me some guidance?
Here's my process:
I separate A-C from B-C and get C with internal forces with equally large opposing forces.
Figure A-C:
Sigma M_A (clockwise is +) = 0
5*2 + 10*2 - 4*C_Ay + 4*C_Ax = 0
=> 30 - 4C_Ay + 4C_Ax = 0, this is (1)
Figure B-C:
Sigma M_B (clockwise is +) = 0
(- cos(arctan(3/4)) * 12 * 2,5) - (sin(arctan(3/4)) * 12 * (tan(arctan(3/4)) * 2,5)) - C_Bx * 3 - C_By *4 = 0
- 37,5 - 3C_Bx - 4 C_By = 0, this is (2)I find an expression for one of the missing values, and put this in the other formula.
And my result is wrong. Always wrong for these tasks. I must do some fundamental error. Any help will be appriciated.
Why are you using negative signs in front of C_Bx and C_By?
Isn't the positive x-direction to the right and the positive y-direction upward?
Because C has internal forces and I assumed direction. Both of which work against momentum. On the other figure there's opposite forces in C. Or am I wrong?
There are various ways to treat signs. If your mathematics is completely consistent then a variable representing an unknown force can be given the "wrong" sign and when you obtain it's value, it will be a negative number. The simplest way to be consistent is to give forces pointing in the positive x or y direction a "+" sign.
How are you doing that? Are you setting C_Ax = C_Bx or are you setting C_Ax = - C_Bx ?
