Statics Question: Finding resultant force and orientation
1 reply · 8K views · last reply
Chandasouk
Free-body diagram of a hook-like ring with two cables: F1 leaves at 30 degrees from the y axis toward the upper right, and F2 leaves at 45 degrees below the x axis toward the lower right.
Determine the magnitude of the resultant force FR. Assume that F1 = 230 and F2 = 395
Express your answer to three significant figures and include the appropriate units.
Determine the direction of the resultant force FR , measured counterclockwise from the positive x axis.
I got the magnitude as 402lb which is correct, but I am having trouble finding the direction of the force.
I have the following work below
http://img5.imageshack.us/img5/1954/resultantforce.png
So I get [itex]\phi[/itex]=71.6 degrees
Now the first quadrant has an angle from F1 to the x-axis that measures at 60 degrees. What I did was 71.6-60 degrees = 11.6 degrees and said that was the angle of the resultant force, but this answer is wrong.
Can anyone explain how to find the angle? Should I be subtracting 360 from 11.6 degrees instead since it wants the position counterclockwise?
Why don't you find the components of F1 and F2 and add them to determine the resultant?
