Statistics: Standard Deviation Prob.
4 replies · 6K views
Mesmer
This is my data: 42.4, 65.7, 29.8, 58.7, 52.1, 55.8, 57.0, 68.7, 67.3, 67.3, 54.3, 54.0 I need to find the standard deviation of this list of data.
2. Homework Equations standard deviation= [tex]: s^2=\frac{\sum_{i=1}^n(x_i -\overline{x})}{n-1}[/tex] Actually the standard deviation is the square root of this expression.
3. I can use a statistics package like minitab or excell to solve this but how would I do it my hand? where would I start?[/b]
Your formula is not correct, is that what messed you up? It should be:
[tex]s^2=\frac{\sum_{i=1}^n(x_i -\overline{x})^2}{n-1}[/tex]
If that was not the problem then is there something you don't know how to do with the formula? Do you know what [itex]x_i[/itex] and [itex]\overline{x}[/itex] are?
[itex]x_i[/itex] represents the data (for example x_1 is 42.4 and x_4 is 58.8)
And [itex]\overline{x}[/itex] is the mean = [tex]\frac{x_1+x_2+...+x_n}{n}[/tex]
Here is an example.
My data are the following: 14.3, 17.5, 15.6
So the mean, [tex]\overline{x} = \frac{14.3+17.5+15.6}{3} = 15.8[/tex]
So then
[tex](x_1 -\overline{x})^2 = (14.3 - 15.8)^2 = (-1.5)^2 = 2.25[/tex]
[tex](x_1 -\overline{x})^2 = (17.5 - 15.8)^2 = (1.7)^2 = 2.89[/tex]
[tex](x_1 -\overline{x})^2 = (15.6 - 15.8)^2 = (-.2)^2 = .04[/tex]
Hence,
[tex]s^2 = \frac{2.25 + 2.89 + .04}{3-1} = \frac{5.18}{2} = 2.59[/tex]
So our standard deviation s is then the square root of that which means s = 1.60935
Thanks, I did latex my equation wrong, but you also cleared up my confusion about how the expression works. :) I see my mistake in understanding now.
The equation is also for variance. If you want to find the actual standard deviation, you'll still need to take the square root of that.
By the way since
[tex]\Sigma_{i=1}^n (x_i- \overline{x})^2= \Sigma_{i=1}^nx^2- \overline{x}\Sigma_{i=1}^n x_i+ \overline{x}^2\Sigma_{i=1}^n 1[/tex]
[tex]= \Sigma_{i=1}^n x_i^2- 2n\overline{x}+ n\overline{x}= \Sigma_{i=1}^n x_i^2- n\overlne{x}[/tex]
(because
[itex]\Sigma_{i=1}^n x_i= n\overline{x}[/itex]
and
[itex]\Sigma_{i=1}^n 1= n[/itex]
[tex]\sigma^2= \frac{1}{n-1}\Sigma_{i=1}^n x_i^2- \frac{n}{n-1}\overline{x}[/tex]
That's often easier to calculate.
