Stethoscope Acoustics: Explaining Low/High Frequency Filtering
  • Context: Undergrad
  • Thread starter Thread starter pkubin
    Acoustics
This discussion focuses on the acoustics of stethoscopes, specifically the filtering characteristics of diaphragms and bells. Stethoscope diaphragms amplify higher frequency sounds due to their lower mass, while bells amplify lower frequency sounds because of their larger mass. The confusion regarding the use of smaller diaphragms in some stethoscopes is clarified; they are designed to transmit lower tones effectively, contrary to the behavior of musical drums where smaller diameters produce higher pitches. Understanding these principles is essential for accurately explaining stethoscope functionality.
  • Basic understanding of sound frequency and acoustics
  • Familiarity with stethoscope components (diaphragm and bell)
  • Knowledge of mass and its effect on sound transmission
  • Awareness of sound amplification principles
  • Research the physics of sound waves and frequency filtering
  • Explore the design differences between various stethoscope models
  • Learn about acoustic principles in medical devices
  • Investigate the impact of diaphragm size on sound quality in stethoscopes
Medical professionals, particularly physician assistants and healthcare educators, as well as individuals interested in the physics of medical instruments and sound acoustics.
pkubin
Hi, everybody. I run a blog about my training as a physician assistant, and I'm planning a video that discusses just how stethoscopes work. I understand the general principle, but I'm having trouble with the WHY for two of the facts I intend to share:
1) Stethoscope diaphragms filter out low frequency sound, and therefore tend to amplify the higher frequency ones
And,
2) Stethoscope Bells -- the side that has a smaller diaphragm, or none at all (just a concavity) -- tend to amplify low frequency sounds.
Is there a fairly simple physics principle that will explain to the non-physicist WHY those two things are true?
Thanks,
Paul
The main difference, from what I can tell, is that the diaphragm picks up sounds (that is, the diaphragm is excited by vibrating air) while the bell is directly excited by (acoustic) movement of the skin.
The amplification in both cases occurs because of the large size of the diaphragm/bell as compared to your eardrum. The bell amplifies low frequencies due to the large mass, while the diaphragm amplifies high frequencies because of the low mass.
http://www.blurtit.com/q505558.html
Okay, that makes sense to me, but I'm still not clear on one issue.
Some stethoscopes, instead of having a diaphragm and a bell, have a diaphragm and a smaller diaphragm that is used in place of a bell. The conventional wisdom is that the smaller diaphragm will transmit the lower tones and the larger will transmit the higher ones.
This confuses me a little, because in a drum set, the smaller the drum diameter, the higher the pitch (if you're not a musician, think of the tympany drums - huge diameter for the low booming sounds) -- and that's just the opposite of the way it seems to work with stethoscopes. Why is that?
Nevermind. It seems I have the large vs. small diaphragm thing backwards. The large is for high frequencies, and the small is for even higher ones in the presence of low ones (that are then more effectively filtered out).
thanks for your answer, Andy.
  • · Replies 20 ·
  • · Replies 75 ·
12K
