What are the design considerations for a 5kW Stirling engine?
Designing a 5kW Stirling engine involves significant challenges, particularly in achieving efficiency, which requires a thermal recuperator and often a two-piston design. While off-the-shelf options exist, they tend to be expensive and specialized, making DIY projects appealing for those with access to machine shops. Solar power applications for Stirling engines have historically faced difficulties in affordability and efficiency, leading many to seek alternative energy solutions. Resources such as SESUSA and various energy journals can provide valuable insights and plans for building or sourcing engines. Overall, creating a functional and efficient 5kW Stirling engine is feasible but requires careful planning and access to appropriate materials and tools.
vidarth
Hey,
I'm an electrical engineering student and I'm trying to design a solar dish which converts the heat from sunlight into electricity. I managed to make a small stirling engine with the results i got from google (The stirling engines made from coke cans). I was wondering how costly it would be to actually make or even buy a stirling engine of about 5 KW capacity.
Please reply if you have any experience with working with stirling engines.
Thank you,
Vidarth
Making the Stirling engine is easy. Its making one that's efficient which is tough. In order to get even reasonable efficiency a thermal recuperator is required. The more efficient and less complicated designs use two pistons with a the recuperator in between them.
http://blog.steamshift.com/wp-content/uploads/moved/stirling_engine.gif
Making something like this for 5kW would be a bit challenging but certainly doable if you got a mill on hand. If you don't have access to a machine shop, I would look at stirling engine electrical generators used in boats as a starting point.
Hey thanks a lot. Can you post some links about plans for a 5 kw stirling engine as i have access to a machine shop at university. Also do you know if any companies sell these commercially?
Check out a group on Yahoo called SESUSA. Somebody there could help you out. I don't think you'll have much luck getting one to run off of solar power. People have spent millions trying to do it right and they could never make it affordable, despite decent results from the engine. Most the engines made at home aren't very efficient so starting with a low temp source like solar will probably doom you.
I have been "collecting" various yard related engines for this kind of purpose. you can decrease your cost of manufacture significantly with pistons, cylinders, and crank assy's "off the shelf. I am still looking for some "scroungable" engine with 90 degree cyl spacing, but the closest so far is an "old Mopar" air conditioning compressor. search google books for hot air engines and you should yield up some added info in a historical sense, but it still helps.
dr
When I look at that picture the first thought is a model airplane engine, the second thought is a TEE pipe fitting, two opposed pistons in regular pipe sleeves, and a special machined aluminum or copper top sleeve. Charge it with propane and it should be a very cheap way to build. (use X or XX pipe fittings).
Bore the TEE through the center and weld a short nipple on each side to hold crankshaft bearings, then a pipe cap on each side will make a leak proof design.
To take power off don't forget about magnetic couplers, there are units that transfer a lot of power.
Ron
P.S. I have no idea what power, but 4" might get close?
13K
