Stoichiometric ratio calculation
  • Thread starter Thread starter Rajini
    Calculation Ratio
The discussion focuses on calculating the stoichiometric ratio for synthesizing the superconducting compound Nd[O0.89F0.11]FeAs, as outlined in the paper with DOI: 10.1209/0295-5075/82/57002. Participants confirm that to prepare one mole of Nd[O0.89F0.11]FeAs, the required amounts of Nd, As, Fe, Fe2O3, and FeF3 must be calculated based on their respective molar contributions. The balanced equation provided is Nd + As + 0.3699Fe + 0.2967Fe2O3 + 0.0367FeF3, which allows for precise calculations of the grams needed for each compound.
  • Understanding of stoichiometry in chemical reactions
  • Familiarity with superconducting compounds and their synthesis
  • Knowledge of molar calculations and conversions
  • Basic chemistry skills, particularly in balancing equations with non-integer coefficients
  • Research the synthesis methods for superconducting compounds, particularly Nd[O0.89F0.11]FeAs
  • Learn about the role of each component (Nd, As, Fe, Fe2O3, FeF3) in the synthesis process
  • Study advanced stoichiometry techniques for compounds with non-integer coefficients
  • Explore the properties and applications of Nd[O0.89F0.11]FeAs in superconductivity
Chemists, materials scientists, and researchers involved in the synthesis of superconducting materials will benefit from this discussion, particularly those focusing on stoichiometric calculations and compound preparation.
Rajini
Dear all,
I am trying to synthesis a compound as given the paper below. Can someone help me of how to calculate the stoichiometric ratio and amount of each compound (i.e. Nd pieces, As, Fe, Fe2O3, FeF3 powders) required to prepare the same compound as in that paper. Especially I don’t know the balanced equation.
Preparation of superconducting compound is given in the following paper:
Doi: 10.1209/0295-5075/82/57002
The superconducting compound is Nd[O0.89F0.11]FeAs.
It is mentioned in that paper as follows:
Nd pieces, As, Fe, Fe2O3,FeF3 powders (the purities of all starting chemicals are better than 99.99%) were mixed together according to the nominal stoichiometric ratio of Nd[O0.89F0.11]FeAs, then ground thoroughly and pressed into small pellets.
thanks and regards, Rajini.
Chemistry news on Phys.org
You can't balance a reaction in a standard way, when the compound has non-integer coefficients. But the stoichiometry still holds - 1 mole of Nd[O0.89F0.11]FeAs contains 1 mole of Nd, 1 mole of Fe, 1 mole of As, 0.89 moles of O and 0.11 moles of F. Assume you are going to make 1 mole. Start calculating how much Fe2O3 you need to get correct amount of oxygen, then how much FeF3 for fluorides, then check how much Fe you already have and calculate how much Fe to add to make its total up to 1 mole. The rest should be obvious.
solved
Hello Borek,
I got your suggestion:
Is the following correct?
Nd + As + 0.3699Fe + 0.2967 Fe2O3 + 0.0367 FeF3 -> Nd[O0.89F0.11]FeAs.
I think I can now calculate grams of each compound reruired to prepare..
Regards, Rajini.
Looks OK to me.
  • · Replies 19 ·
10K
31K
