Stoichiometry reaction of FeCr2O4 with K2CO3
The reaction of FeCr2O4 with K2CO3 and O2 at high temperatures produces K2CrO4, Fe2O3, and CO2. The balanced chemical equation is 4 FeCr2O4 + 8 K2CO3 + 7 O2 --> 8 K2CrO4 + 2 Fe2O3 + 8 CO2. Initial calculations indicated an efficiency of 55.7%, but the correct efficiency is 66.2%. The discussion highlights the importance of balancing potassium, oxygen, and carbon in stoichiometric calculations.
  • Understanding of stoichiometry and chemical reactions
  • Familiarity with balancing chemical equations
  • Knowledge of limiting reagents in chemical reactions
  • Basic skills in calculating reaction efficiencies
  • Study the concept of limiting reagents in more detail
  • Learn about calculating reaction efficiencies in chemical processes
  • Explore advanced stoichiometry techniques for complex reactions
  • Review the principles of balancing chemical equations
Chemistry students, chemical engineers, and professionals involved in reaction optimization and efficiency calculations in chemical processes.
th3whit3fang
1) K2CrO4 is produced by the reaction of FeCr2O4 with K2CO3 and O2 in a high temperature. This reaction also produces Fe2O3 and CO2.
If 169 kg FeCr2O4 reacts with 298 kg K2CO3 and 75 kg O2 and so it produces 194kg K2CrO4 then calculate the efficiency of this reaction.2) The equations is: 4 FeCr2O4 + 3 K2CO3 + 7 O2 --> 8 K2CrO4 + 2 Fe2O3 + 8 CO2
169 kg 298 kg 75 kg 194 kg 3) I first calculated the weights (2 Fe2O3 + 8 CO2) which were missing:
weight(2 Fe2O3 + 8 CO2) = (169 kg + 298 kg + 75 kg ) - 194 kg = 348 kg
and ther for the efficiency, i divided the weight of 8 K2CrO4 by 348 kg: 194 kg/ 348 kg = 55.7 %
It wasn't correct .. the correct answer is 66,2 %.
Potassium is not balanced (nor oxygen, nor carbon).
This is a limiting reagent problem. Calculate how much K2CrO4 should be made from given amounts of reactants.
Sorry, i made a mistake while typing. it should be:
Thank you and i have another questi0n: can K2CrO4 the smallest limiting reagant?
i took it as the smallest limiting reagent .. and i calculated the weight of the other susbstances...
and then i divided the weight of K2CrO4 by the weight of FeCr2O4 + K2CO3 + O2.. is this how you calculate the efficiency ?
16K
19K
