Storing silver nitrate solution
  • Thread starter Thread starter skyshrimp
    Silver
skyshrimp
I'm going to attempt the Mohr's Method chloride test at home for my saltwater aquarium.
It requires me to add 5g of sliver nitrate to 250ml of distilled water and store it in a brown bottle. I have an opaque, black 750ml bottle I can use that I washed out with 0 TDS water. It used to contain Bailey's Liquor and has a metal screw top lid. Will this be ok to use? Can I use a plastic bottle to store it in instead?
I don't have the equipment to distill so I kept partially freezing tapwater and retaining the ice until the TDS was 0.
I also have to mix 1g of potassium chromate with 20ml of distilled water. Would this have to be in a glass bottle or can I use a plastic one?
Thanks
Chemistry news on Phys.org
Don't ever use bottles that were earlier used to keep any food for reagents. Not because of possible contamination, but to avoid nasty mistakes. Few years ago a kid died in Warsaw after drinking some kind of wood protection liquid that her grandpa kept in a coca cola bottle.
If you keep your reagents in a dark cabinet, using brown bottles don't matter much.
I would prefer glass bottles for both silver nitrate and dichromate.
http://www.titrations.info/precipitation-titration-argentometry-chlorides-Mohr
skyshrimp said:
(snip) ... has a metal screw top lid. (Big no-no for AgNO3) Can I use a plastic bottle to store it in instead? Should be okay as long as you keep it in the dark; caveat: it will embrittle plastic over time, so if you can store your plastic bottle in a glass jar, it'll do wonders for preserving the finish on your furniture.
I don't have the equipment to distill so I kept partially freezing tapwater and retaining the ice until the TDS was 0. Outstanding --- didn't think there was anyone else in the world as eccentric that way as yours truly.
Ought to be okay, same caution.
Thanks
Thanks,
So if I used glass bottles, how should I seal them if I can't use their metal screw caps?
Glass stoppers are the best, but I guess you don't have them. Polyethylene plastic stoppers are quite good as well. If you have neither, cork stoppers wrapped in polyethylene foil should work as a last resort.
