Stress-energy tensor definition
7 replies · 2K views
coleman123
I have seen two definitions with oposite signs (for one of the pressure terms in the formula) all over the web and books. I suspect it is related to the chosen metric signature, but I found no references to that.
General Relativity An Introduction for Physicists from M. P. HOBSON, G. P. EFSTATHIOU and A. N. LASENBY uses a negative sign.
Wald uses a positive sign..
And so on..
What's happening?
I don't think the signature matters. Stephani uses a + sign like your first example. I always used this form so it looks as if H, E & L are in a minority.
The coefficient of P is a projection operator into the 3-space orthogonal to uμ. If you use ημν = (1, -1, -1, -1) it should be uμuν - ημν, while if you use ημν = (-1, 1, 1, 1) it should be uμuν + ημν.
I guess that sorts out the issue.
Thanks Bill. So the metric matters then. In the end I was just using:
Tμν=(ρ+P/c2)uμuν-sPgμν
where "s" is the sign corresponding to the time coordinate.
Where do I find more about this?
Thank you
I'm not sure what you're looking for, but there's an online treatment of relativistic fluid dynamics http://relativity.livingreviews.org/open?pubNo=lrr-2007-1&page=articlese6.html that's rather complete.
That's it. Thanks again
