String theory-connecting strings
In summary, in bosonic string theory, the critical dimension is D=26. In superstring theory, the critical dimension is D=10. Non-critical strings in other dimensions are also explored. Bosonic string theory isn't a workable theory, however, as it contains tachyons (and has an unstable vacuum as a result).
pforeman
I take it strings are too small to have "connectors" on their ends, there is no glue etc. so how could strings combine to become larger particles like bosons.
I have never heard anyone describe the reason for the extra dimensions that string theory says are there.
Could it be that these strings are forced together because they are trapped in a universe barely large enough to hold the strings (these tiny extra dimensions)
In other words, one of these extra dimensions contain 3 strings which become a boson perhaps another dimension can contain several bosons and becomes the strong nuclear force.
Each tiny dimension is a universe unto itself, from which obviously nothing can escape.
Thanks
Paul
Why do you suppose that strings "combine" to form bosons? Bosons are elementary particles and so correspond to the excitations of single strings.
There are important technical reasons; in particular, something called anomaly cancellation that only occurs in set numbers of dimensions.
To explain a little bit about what this means, imagine we want to describe the physics of a rubber band. What we're going to do, first, is write some numbers down to describe the rubber band. This shouldn't be an important operation: what numbers we use to describe the band should have no impact on how the band behaves. They're just our description, after all.
This is a rather important feature of any reasonable theory of our universe: the representation used to describe it shouldn't have any impact on how the theory behaves.
But in string theory, when you write down how the behavior of objects changes when you change the numbers used to describe them, you get these extra terms called, "anomalies." These anomalies make no physical sense. But they do disappear neatly in certain specific numbers of dimensions (either 10 or 26 depending upon the underlying description).
In string theory Lorentz invariance preserved only in 26 dimension.
In bosonic string theory, yes, the critical dimension is D=26. In superstring theory, the critical dimension is D=10. But string theorists also explore non-critical strings in other dimensions.
Bosonic string theory isn't a workable theory, however, as it contains tachyons (and has an unstable vacuum as a result). But heterotic string theory works just fine, and it has 26 dimensions.
1. What is string theory and how does it work?
String theory is a theoretical framework in physics that aims to unify all the fundamental forces and particles in the universe. It proposes that the fundamental building blocks of the universe are not point-like particles, but tiny strings that vibrate at different frequencies. These vibrations give rise to the different particles and forces we observe in nature.
2. How does string theory connect strings?
String theory proposes that the strings are connected to each other in a multidimensional space called the "bulk." The strings can interact and exchange energy and information with each other through this bulk, allowing for the creation of different particles and forces.
3. What is the purpose of connecting strings in string theory?
The purpose of connecting strings in string theory is to provide a unified framework for understanding all the fundamental forces and particles in the universe. By connecting strings, string theory attempts to explain the underlying structure of our universe and how everything is interconnected.
4. How is string theory different from other theories in physics?
String theory is different from other theories in physics because it is a theory of quantum gravity, meaning it attempts to reconcile the principles of quantum mechanics and general relativity. It also proposes a different view of the fundamental building blocks of the universe, as well as the existence of extra dimensions beyond the four dimensions of space and time.
5. Are there any experimental proofs for string theory?
Currently, there is no experimental evidence to prove or disprove string theory. It is still a highly theoretical and speculative concept that is being studied and tested by physicists. However, some mathematical predictions of string theory, such as the existence of gravitons and the number of dimensions, have been supported by experiments and observations.
  • Beyond the Standard Models
