MHB What Are the Subgroups of Z_n When n Is Even?
  • Thread starter Thread starter alyafey22
    even
The discussion centers on the subgroup structure of the cyclic group $\mathbb{Z}_n$ when $n$ is an even positive integer. It is established that for any subgroup $H$ of $\mathbb{Z}_n$, either all elements of $H$ are even or exactly half of the elements are even. This conclusion is derived through case analysis of subgroups generated by various elements, including $0$, $1$, and $2$. The discussion also emphasizes the application of Lagrange's theorem and the definition of evenness within the context of cyclic groups.
  • Understanding of cyclic groups and their properties
  • Familiarity with subgroup generation in group theory
  • Knowledge of Lagrange's theorem in abstract algebra
  • Basic definitions of even and odd integers in modular arithmetic
  • Study Lagrange's theorem in detail and its implications for subgroup orders
  • Explore the properties of cyclic groups, specifically $\mathbb{Z}_n$
  • Learn about subgroup generation and its applications in group theory
  • Investigate modular arithmetic and its definitions of evenness and oddness
Students of abstract algebra, particularly those studying group theory, as well as educators and researchers interested in the properties of cyclic groups and subgroup structures.
alyafey22
MHB
Contemporary Abstract Algebra by Gallian
This is Exercise 24 Chapter 3 Page 70
Question
Suppose $n$ is an even positve integer and $H$ is a subgroup of $\mathbb{Z}_n$. Prove that either every member of $H$ is even or exactly half of the members of $H$ are even
Attempt
We consider some cases :
[1] The subgroup generated by the identity $0$ then $H=<0>=\{0\}$ hence all members are even .
[2] The subgroup generated by $1$ , $H=G$ and since the ordere of $G$ is even , we have half the members are even.
[3] The subgroup generated by $2$, $H=<2>=\{0,2,4,6 , \cdots , 2n\}$
hence all members are even.
[4] The subgroup generated by $n$ , $H=<n>=\{0,n\}$. If $n$ is even then subgroup contains even integers. If $n$ is odd half the members are even.
Since $\mathbb{Z}_n$ is cyclic every subgroup is cyclic. So it suffices to look at the subgroups generated by each even and odd element. I am taking this theorem from another latter chapter so I guess I shouldn't be able to use the properties of cyclic groups.
Any hint how to proceed ?
The theorem stated is equivalent to this one:
Let $K$ be the subgroup of "even" elements. Then either:
1. $|K \cap H| = |H|$
or:
2. $|K \cap H| = \dfrac{|H|}{2}$.
Some observations about your observations:
Your description of the subgroup generated by $n$ is incorrect: in $\Bbb Z_n$ we have that:
$[n] = [0]$, since $n \equiv 0 \text{ (mod } n)$.
Before I go any further, might I ask: have you covered Lagrange's theorem yet?
I actually abused the notations. Since $n$ is even we have $n=2k$ for some positive $k$ then we have the subgroup generated by $k$ contains $\{0,k\}$.
No, we only covered groups ,subgroups tests and examples of subgroups.
Re: Supgroups of Z_n when n is even
OK. In this case, note that "even" only makes sense when $n$ is an even integer, for if $n$ is odd, "skipping by 2's" lands on every element.
Also note that we can't use our "usual" definition of "even": that $k$ is even if 2 divides $k$, because "divides" doesn't always make sense in $\Bbb Z_n$ (consider $n = 6$ and what "division by 3" could possibly mean).
SO we have to use THIS definition:
$[k]$ is even if $[k]$ is in the subgroup generated by $[2]$ which is:
$\{[0],[2],[4],...,[n-2]\}$.
Equivalently, $[k]$ is even if $k$ is even.
Now, let's do this:
Suppose $H = \{[0],[k_1],...,[k_r]\}$ with:
$1 \leq k_1 <\dots < k_r < n$.
Claim 1:
$H$ consists solely of sums:
$[k_1], 2[k_1],\dots,s[k_1] = [0]$ (here, $t[k_1]$ is a $t$-fold sum of $k_1$ with itself).
Clearly any such sum is in $H$ by closure. Since we have an infinite number of such sums, and $H$ is finite, it must be that for two positive integers $t_1 < t_2$:
$t_1[k_1] = t_2[k_1]$, so $(t_2 - t_1)[k_1] = [0]$.
Since any non-empty set of positive integers has a least element, we have a least such positive integer, $s$. I claim that $s$ divides $n$ and moreover, that $k_1$ does, as well.
Write $n = qk_1 + r$, where $r = 0$ or $r < k_1$.
In $H$, this becomes:
$[0] = q[k_1] + [r]$, showing that $[r] \in H$. Since we chose $k_1$ to be minimal, $r = 0$.
This shows that $k_1$ divides $n$.
Now suppose $k_j$ is not a multiple of $k_1$. Again, we can write:
$k_j = q'k_1 + r'$, and by the same reasoning, we must have $r' = 0$, which contradicts our assumption that $k_j$ is not a multiple of $k_1$.
But now we see that the smallest positive integer $s$ for which $s[k_1] = [0]$ (in $\Bbb Z_n$) must be the $q$ we posited earlier, since for every smaller positive integer $t$, we have:
$tk_1 = k_j < n$.
This proves claim 1.
We now consider two cases:
Case 1: $k_1$ is even.
In this case, we see every element of $H$ is even.
Case 2: $k_1$ is odd. In this case, since $sk_1 = n$ and $n$ is even, We must have an even number of elements in $H$, namely:
$[k_1],2[k_1],\dots,(s-1)[k_1],[0]$.
Clearly, every other element is even, and there are $s/2$ such elements.
11K
  • · Replies 26 ·
