Substitution y=tx in first order differential equation
2 replies · 2K views
squareroot
I'm starting college this autumn(physics) and I started learning some calculus on my own, basic stuff like first order differential equation and so on.Recently i stumbled on something that i don t understand.I was reading the course and re-solving the given examples for myself.So you have the equation
[tex]\frac{dy}{dx} = \frac{ \frac{y}{x} - 1 }{ \frac{y}{x} + 1 }[/tex]
calculus
Given that the equation is already solved but i didn't understand one of the steps if the solutions i'll show you where i get stuck.
So you substitute y=tx and here comes the boom, by doing this substitution they say the result is
[tex]\frac{t+1}{t<sup>2</sup>+1}dt =-\frac{dx}{x}[/tex] and from here on it s quite simple, you just integrate both sides and get the result.But i didn't understand the steps from substituting y=xt to getting to that result.I ll show you how i tried to solve it but got to a different result.
So if y=tx --> dy/dx=tdx and it s clear that if you substitute dy/dx in that equation you don t get their answer.
My main problem is that, in high school we didn't use this notation, we used f'(x) instead of dy/dx and so on, so I'm having a bit of trouble getting used with this notation, but these are the one used in physics so now i have to squash my brains a little and try to get used to them.
If someone can explain that step to me and maybe give me a few tips on how to make the transition between these two notation easier it would be great!
Thank you
"Here comes the boom"?
Seeing the "y/x" on the right, I think it would be obvious to set [itex]t= y/x[/itex] which is the same as [itex]y= xt[/itex]. Differentiating both sides with respect to x,
[tex]\frac{dy}{dx}= x\frac{dt}{dx}+ t[/tex].
And the whole point of that substitution is that
[tex]\frac{\frac{y}{x}- 1}{\frac{y}{x}+ 1}= \frac{t- 1}{t+ 1}[/tex]
So the equation becomes
[tex]x\frac{dt}{dx}+ t= \frac{t- 1}{t+ 1}[/tex]
[tex]x\frac{dt}{dx}= \frac{t-1}{t+ 1}- t= \frac{t- 1}{t+ 1}- \frac{t(t+ 1)}{t+1}[/tex] Combine the fractions on the right and you have a relatively simple "separable" equation.
(Personally, I thing [itex]dy/dx[/itex] is a better notation than y' but you can translate back:
y'= (y/x- 1)/(y/x+ 1). Let t= y/x so that y= xt and y'= xt'+ t. The equation becomes [itex]xt'+ t= (t- 1)/(t+ 1)[/itex]. [itex]xt'= (t- 1)/(t+ 1)- t= (t- 1)/(t+ 1)- (t(t+ 1))/(t+ 1)[/itex]. Of course, when you learned integration, you must have learned that if y'= f(x) then [itex]y= \int f(x)dx[/itex] which follows more easily from [itex]dy/dx= f(x)[/itex], [itex]dy= f(x)dx[/itex].)
