Suggest a geometry for headphone's speaker system
3 replies · 2K views
mirreb9
Summary:: Suggest a geometry
Hello! I have difficulties with this question. It is translated from Swedish so if something's weird tell me.
The speakers in headphones often work with the help of magnetism, when a varying voltage is applied across a coil attached to the speaker membrane. The coil is in the field from a permanent magnet, so the current through the coil will create a force on the coil so that it moves. You have access to signal, short coil, rod-shaped permanent magnet and diaphragm. Suggest a geometry that can accomplish this. Motivate your answer.
I have mostly difficulties with the motivation part, i think i have made the right drawing.
(This is not the geometry used commercially. It has a different shape of the permanent magnet for more efficient energy transfer.)
Thanks in advance!
The translation isn't fluent.
Their saying, given an input signal, a short coil of wire, a rod-shaped permanent magnet, and a diaphragm, show how to assemble these parts and describe how it would work.
That said, this is a homework problem - so you need to show us your attempt to solve it before you get any direction from us.
See the homework guidelines here:
Guidelines
Guidelines
Thank you! I will look at the guidelines.
Welcome to the PF. I have moved your thread to the schoolwork forums for you. :smile:
Thanks in advance!
It would help if we could see your drawing. Use the "Attach files" link in the lower left of the Edit window to add a PDF or JPEG file to show us your work so far. Please try to be sure that the image is clear and upright. Thanks. :smile:
