Can you construct a sequence of real nonzero numbers whose sum converges to 0?
  • Thread starter Thread starter Bipolarity
    Converging Sum
A sequence of real nonzero numbers whose sum converges to 0 can indeed be constructed, as demonstrated by various formulas and series. One proposed sequence is given by the alternating series \sum^{\infty}_{n=1} (-1)^{n+1} (\frac{1}{2})^{\frac{2n-3+(-1)^{n+1}}{4}}, which is believed to converge to 0. The discussion highlights the importance of expressing series with nonzero terms, as this is a requirement for the problem. Several examples and alternative constructions are suggested, emphasizing that various sequences can be formulated to achieve the desired convergence. The conversation reflects a deep exploration of series properties and convergence criteria.
Bipolarity
Does there exist a sequence of real nonzero numbers whose sum converges to 0?
I would think there isn't, but I'm interested in people's opinions and arguments.
For any nonzero m, a series of nonzero numbers whose sum converges to m can easily be constructed using the formula: \sum ^{\infty}_{n=1}m(0.5)^{n}
But that is for nonzero m, what if you wanted to construct a series whose sum converged to 0?
BiP
1+-1+.5+-5+.25+-.25+.125+-.125+...
Can you find an explicit representation for that seqence (i.e. with sigma notation) ?
BiP
Eureka! I believe I found it!
\sum^{\infty}_{n=1} (-1)^{n+1} (\frac{1}{2})^{ \frac{2n-3+(-1)^{n+1}}{4}}
I believe it converges to 0, but can anyone verify this?
BiP
If \sum ^{\infty}_{n=1}m(0.5)^{n} converges to m, then shouldn't m-\sum ^{\infty}_{n=1}m(0.5)^{n} converge to 0?
Yes, but m-\sum ^{\infty}_{n=1}m(0.5)^{n} is not a series... unless you can express it as one with nonzero terms.
BiP
Who cares about expressing it as one with nonzero terms? A series is a series is a series.
This is simple
How about
\sum_{n=0}^\infty \frac{(\pi)^{2n+1}}{(2n+1)!} (-1)^n
The problem requires it.
BiP
How about (1-λ)λn-(1-μ)μn for n >= 0, where λ is algebraic and μ is not?
How about taking a sequence (a_x)_x which satisfies \displaystyle \lim_{x\to\infty}a_x = 0 and then using the series \displaystyle \sum_{x=0}^{\infty} (-1)^x b_x, where the sequence b_x is defined as b_{2x} = b_{2x+1} = a_x?
So you dislike the pi example and the usual example
\sum_{k=0}^\infty a_k b_x
where a_k is a sequence of positive numbers tending to zero and B_k is any sequence of -1 and 1 such that the series tends to zero.
What about any number of obvious examples such as
\sum_{k=0}^\infty (2k-1)\left(\frac{1}{3}\right)^k
  • · Replies 24 ·
  • · Replies 37 ·
  • · Replies 17 ·
