Sum independent normal variables
- Level: Undergrad
- Thread starter mathman
- Start date
- Tags
- Independent Normal Sum Variables
39 replies · 6K views · last reply
Discussion
Mentor
- 37,359
- 16,495
Independence is necessary. Suppose, for example that ##X_1 \sim \mathcal{N}(\mu=0,\sigma=1)## and ##X_2 = -X_1## then ##X_2 \sim \mathcal{N}(\mu=0,\sigma=1)## but ##X_1+X_2=0## which is not normally distributed.
Homework Helper
- 8,130
- 575
I was wondering about random variables which are correlated, but with##|\rho|\lt 1## or in general as long as they are linearly in dependent. In that case they could be transformed into a set of independent random variables.Dale said:Independence is necessary. Suppose, for example that ##X_1 \sim \mathcal{N}(\mu=0,\sigma=1)## and ##X_2 = -X_1## then ##X_2 \sim \mathcal{N}(\mu=0,\sigma=1)## but ##X_1+X_2=0## which is not normally distributed.
- 597
your original claim is true iff they are jointly normally distributed. This is implied by the standard claim that an random n-vector is a multivariate gaussian iff every 1-dimensional marginal one is a normal r.v.
It depends on pedantry, but Dale's counterexample actually isn't one-- it is just a case of a "normal random variable" with mean zero and variance of zero. Not particularly satisfying but it is useful as a vacuous truth.
BWV
- 1,690
- 2,023
by the CLT, a finite sum of random variables from any distribution with finite variance will converge to normal
On the sum of 2 normals, some proofs in wikipedia
https://en.wikipedia.org/wiki/Sum_of_normally_distributed_random_variables
BWV
- 1,690
- 2,023
A proof w/ MGFs would have the same form the characteristic function proof in the linkWWGD said:Iirc ,you can use generating functions for the proof.
Homework Helper
Education Advisor
- 7,864
- 1,605
Are their theorems that deal with the general question? - Given a set of random variables ##\{X_1,X_2,..,X_M\}##, when does their exist some subspace ##S## of the vector space of random variables such that ##S## contains each ##X_i## and ##S## has a basis of mutually independent random variables?
"Linearly independent" presumably implies we are considering a set of random variables to be a vector space under the operations of multiplication by scalars and addition of the random variables.
Suppose we take "transformed" to mean transformed by a linear transformation in a vector space. If the vector space containing the random variables ##{X_1,X_2,...X_M}## has a finite basis ##B_1,B_2,...B_n## consisting of mutually independent random variables then (trivially) for each ##X_k## there exists a possibly non-invertible linear transformation ##T## that transforms some linear combination of the ##B_i## into ##X_k##.
If the smallest vector space containing the ##X_i## is infinite dimensional (e.g the vector space of all measurable functions on the real number line) , I don't know what happens.
I don't recall any texts that focus on vector spaces of random variables. Since the product of random variables is also a random variable, the topic for textbooks seems to be the algebra of random variables. But that approach downplays the concept of probability distributions.
mathman said:I was wondering about random variables which are correlated, but with##|\rho|\lt 1## or in general as long as they are linearly in dependent.
Homework Helper
- 8,130
- 575
My original question was specifically for finite sums. The Wiki article gives the answer for a pair of correlated variables which then implies it holds for any finite sum.BWV said:by the CLT, a finite sum of random variables from any distribution with finite variance will converge to normal
BWV
- 1,690
- 2,023
Yes, if that did not work, then all of Modern Portfolio Theory would failmathman said:The Wiki article gives the answer for a pair of correlated variables which then implies it holds for any finite sum.
Staff Emeritus
- 1,592
Stephen Tashi said:Are their theorems that deal with the general question? - Given a set of random variables ##\{X_1,X_2,..,X_M\}##, when does their exist some subspace ##S## of the vector space of random variables such that ##S## contains each ##X_i## and ##S## has a basis of mutually independent random variables?
I'm not sure this is the right question. Given a single random variable, it plus itself is just 2 time itself, since you're not adding two independent copies of itself. So anyone dimensional subspace for example.If you are wondering about sets of random variables that are stable under adding independent copies, then I think it's just the normal random variables, since if you repeatedly add a random variable to itself you get something that slowly deforms into a gaussian. I guess the space of all things deforming into gaussians also works.
Homework Helper
- 7,926
- 13,241
Don't mean to go far OT, but I am kind of curious about transformations that preserve normality.Office_Shredder said:I'm not sure this is the right question. Given a single random variable, it plus itself is just 2 time itself, since you're not adding two independent copies of itself. So anyone dimensional subspace for example.If you are wondering about sets of random variables that are stable under adding independent copies, then I think it's just the normal random variables, since if you repeatedly add a random variable to itself you get something that slowly deforms into a gaussian. I guess the space of all things deforming into gaussians also works.
An interesting thing is that covariance defines an inner product on the space of random variables.
BWV
- 1,690
- 2,023
Wouldn't any linear or affine transformation of a normal RV preserve normality?WWGD said:Don't mean to go far OT, but I am kind of curious about transformations that preserve normality.
Homework Helper
Education Advisor
- 7,864
- 1,605
Yes, the article gives an answer for a pair of correlated normal random variables that have have a joint bivariate normal distribution, but not for more general case of correlated normal random variables whose joint distribution is not specified.
BWV
- 1,690
- 2,023
So if you have the distribution of each component and the covariance, don't you also have the joint distribution?Stephen Tashi said:Yes, the article gives an answer for a pair of correlated normal random variables that have have a joint bivariate normal distribution, but not for more general case of correlated normal random variables whose joint distribution is not specified.
Homework Helper
Education Advisor
- 7,864
- 1,605
BWV said:So if you have the distribution of each component and the covariance, don't you also have the joint distribution?
Not if we believe: https://stats.stackexchange.com/que...d-normal-random-variables-multivariate-normal
Homework Helper
Education Advisor
- 7,864
- 1,605
BWV said:Wouldn't any linear or affine transformation of a normal RV preserve normality?
I'd say yes,
The topic
could include all transformations that preserve normality so perhaps it should be specialized to particular kinds of transformation to eliminate relatively trivial ones. For example if ##X## has a normal distribution with mean zero and we define the transformation ##T(x) = x## except for x = 3 or -3, where we define T(x) = -x, have we have transformed ##X## to a (technically) different normally distributed random variable?but I am kind of curious about transformations that preserve normality.
Homework Helper
Education Advisor
- 7,864
- 1,605
The question I propose is whether each ##X_i## is an element of the same subspace ##S##. So the fact that each ##X_i## can be regarded as being in the 1 dimensional subspace generated by itself, doesn't answer that.Office_Shredder said:I'm not sure this is the right question. Given a single random variable, it plus itself is just 2 time itself, since you're not adding two independent copies of itself. So anyone dimensional subspace for example.
Homework Helper
Education Advisor
- 7,864
- 1,605
An example from stackexchange: https://math.stackexchange.com/questions/878694/sum-of-dependent-normal-random-variables
Canonical (counter)example: Assume that ξ is standard normal and that η=σξ, where σ=±1 is symmetric Bernoulli and independent of ξ. Then η is standard normal but ξ+η is not normal since P(ξ+η=0)=P(σ=−1)=1/2.
BWV
- 1,690
- 2,023
Seems bogus to me, as η contains a discontinuous function σ , and is only 'Normal' because the Bernoulli distribution is hidden until you add it to ξ. I think if you wrote out the characteristic functions for the example like in the proof here: https://en.wikipedia.org/wiki/Sum_of_normally_distributed_random_variablesStephen Tashi said:An example from stackexchange: https://math.stackexchange.com/questions/878694/sum-of-dependent-normal-random-variables
, it would be obvious as you would have the composition of Bernoulli CF of
Homework Helper
Education Advisor
- 7,864
- 1,605
BWV said:Seems bogus to me, as η contains a discontinuous function σ
How would we state a theorem that avoids that counterexample?
If we say "Let ##\eta## be a normally distributed random variable that does not contain a discontinuous function", what would that mean?
On attempt to define "##\eta## does not contain a discontinuous function" might be: There doesn not exist a finite set of random variables ##\{X_1, X_2,...,X_n\}## such that at least one of the ##X_i## does not have a continuous distribution and such that for some function ##f## we have ##\eta = f(X_1,X_2,...X_n)##. However, given such great freedom for people to choose ##f## and the ##X_i## we might eliminate all normally distributed ##\eta## from consideration.
In practical situations the evidence about how ##\eta## can be represented as functions of other random variables would come from joint measurements of ##\eta## and those random variables or functions of those random variables. So perhaps the definition would need to be of the form "##\eta## does not contain a discontinuous function with respect to the random variable ##X## means that ...".
Homework Helper
Education Advisor
- 7,864
- 1,605
WWGD said:It seems we can set the Copula in such a way that the sum violates normality. I will give it a try, should be a nice exercise. Never tried it before, but should work.
Be careful! https://en.wikipedia.org/wiki/David_X._Li
BWV
- 1,690
- 2,023
Stephen Tashi said:How would we state a theorem that avoids that counterexample?
Just also define the generating process for the RV - perhaps the sum of normally distributed RVs where each can be completely described by the Gaussian MGF or CF
Homework Helper
Education Advisor
- 7,864
- 1,605
BWV said:Just also define the generating process for the RV - perhaps the sum of normally distributed RVs where each can be completely described by the Gaussian MGF or CF
However, the existence of one sort of generating process for a random variable doesn't rule out the existence of a different generating processes for it.
I think the goal is prove a theorem of the form:
If ##X## and ##Y## are normally distributed random variables with joint distribution ##J(X,Y)## and ... some conditions... then X + Y is normally distributed.
To get anything interesting the "some conditions" must be conditions that aren't trivially equivalent to assuming ##J(X,Y)## is a bivariate normal distribution.
BWV
- 1,690
- 2,023
Also if D is the Dirichlet Function and A is a standard normal is B= D(A)*A normal? Seems it would pass the measure theoretic criteria - it is L-integrable for example. But if C is another standard normal, then C-B has measure zero
BWV
- 1,690
- 2,023
Stephen Tashi said:However, the existence of one sort of generating process for a random variable doesn't rule out the existence of a different generating processes for it.
but you have to define normal by some generating function. If A = the sum of 100 uniform RVs is A normal? In practice it would be treated as such, but then there is some arbitrary number of uniform RVs where the sum is not normal. If you use the full limit and A is the infinite sum of appropriately scaled uniform RVs, then you could subtract some RH unbounded interval in the sum, which would also be normal, and get a non-normal RV
- TheFallen018
- · Replies 1 ·
- Set Theory, Logic, Probability, Statistics
- Replies
- 1
- Chatman100
- · Replies 2 ·
- Replies
- 2
Graduate
Expectations of normal variables
- lequan
- · Replies 1 ·
- Replies
- 1
- psie
- · Replies 1 ·
- Replies
- 1
- gradnu
- · Replies 3 ·
- Replies
- 3
- joshthekid
- · Replies 10 ·
- Replies
- 10
- WMDhamnekar
- · Replies 2 ·
- Replies
- 2
- stattheory
- · Replies 1 ·
- Replies
- 1
- leothelion
- · Replies 12 ·
- Replies
- 12
- Apteronotus
- · Replies 3 ·
- Replies
- 3
