Sum of All Possible Values for Sn to be a Perfect Square?
  • Thread starter Thread starter physics kiddy
    Algebra
The problem involves determining the values of \( n \) for which the expression \( S_n = n^2 + 20n + 12 \) results in a perfect square, where \( n \) is a positive integer.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss factoring the expression and explore the implications of setting \( (n+10)^2 - 88 \) equal to a perfect square. There are attempts to factor the resulting equation and analyze the properties of the factors of 88.
Several participants have engaged in exploring different factor pairs of 88 and their implications for the values of \( n \). Some guidance has been offered regarding the parity of the factors, and there is an ongoing exploration of possible values without a clear consensus on the final approach.
Participants are working under the assumption that \( n \) must be a positive integer, and there is a focus on the properties of perfect squares and factorization techniques.
physics kiddy
Let Sn = n2+20n+12, n is a positive integer. What is the sum of all possible values of n for which Sn is a perfect square ?
Well, I tried to factorise it : n2+20n+12 = n2+20n+100-88
=(n+10)2-88. And I conclude that there are infinitely such values of n...
I also tried to search properties of perfect squares but could find none applicable here.
To my surprise, answer is 16 ...
How is it like that ?
Suppose (n+10)^2-88 is a perfect square. Call it k^2. Then (n+10)^2-88=k^2. So (n+10)^2-k^2=88. Start factoring both sides.
That's what I can do without much effort ...
it's
(n+10+k)(n+10-k) = 88
What next ?
it's
What next ?
Start listing ways to factor 88 and try to match the factors with factors on the left. Figure out which ones work.
I guess next we need to factorize 88. It's 11*2^3 ..
How many ways to split that into two factors that you can match with the algebra factorization?
it's
What next ?
There's a shortcut you can use with these. Consider the difference between the factors. Can you say whether it is even or odd? What does that tell you about the parity of the factors?
Since difference of factors is 3 ...
so,
(n+10+k)-(n+10-k)=3
=> 2k=3
=>k=2/3
You have been told, repeatedly, to find all the ways of factoring 88 into two factors. But you still have not done that.
What? How did you come to that conclusion?
so,
(n+10+k)-(n+10-k)=3
=> 2k=3
=>k=2/3
You mean k=3/2. And that just shows that 11*8 is not a factorization you want. Try another one.
Ahh :smile:
Oh my god! It was awfully easy:
Factors of 88 -->
1*88
2*44
4*22
8*11
Assuming
n+10+k = 44 and n+10-k = 2;
we have 2n+20=46 =>2n=26 => n = 13
And putting it in n2+20n+12, we have 441 whose root is 21 ... 1st number = 13
again taking n+10+k = 22
and n+10-k = 4;
2n+20 = 26
=> 2n = 6
=> n = 3 ... 2nd number
so
(3)^2+20(3)+12 = 81 root of which is 9...
so the two numbers 13 and 3 add up to 16, that's it.
Thanks everybody a lot.
Just to explain the shortcut I was trying to get you to find, the difference of the factors is 2k, so even. Therefore the two factors are either both even or both odd. Since the product is even, they must both be even. So you can start by assigning a factor of 2 to each, and then you are just left with either 1 x22 or 2 x11 for the remaining 22.
Yea, that also works and even better, no need to search other factors. Thanks a lot. I tried it also.
9K
14K
