Sum of two line subspaces in R^2 closure under addition
6 replies · 2K views
tylerc1991
Learning about sums of subspaces and wanted to be sure that I am understanding this correctly. Say that I have two subspaces of R^2:
U = {(x,y) in R^2 : y + 2x = 0}
W = {(x,y) in R^2 : y - 3x = 0}
and I wanted to geometrically (and algebraically) represent their sum. What would it look like?
Geometrically: since U is the line y = -2x and W is the line y = 3x, their sum, U + W, would be represented by both lines y = -2x and y = 3x appearing on one plane. But I am getting hung up on this new set, U + W, being closed even under addition. Ex: take the point (1,-2) from U and (1,3) from W, their sum is (2,1) which is not on either line y = -2x or y = 3x. What am I doing wrong here?
Algebraically: basing this off of the geometric interpretation, I would say that the sum of U + W would be represented by the set: {(x,y) in R^2 : y + 2x = 0 or y - 3x = 0}, but I am getting hung up on the same problems I was having with the geometric interpretation.
Thank you anyone for your help!
Hi tylerc1991! :smile:
What you seem to be doing is [itex]U\cup W[/itex], but like you notice, nobody says that this is closed uner addition, and it isn't.
What U+W actually is, is the space spanned by [itex]U\cup W[/itex]. So you've correctly calculated that
[tex]U\cup W=\{(x,y)\in \mathbb{R}^2~\vert~y + 2x = 0~\text{or}~y - 3x = 0\}[/tex]
but you still need to take the span of it.
To do this efficiently, take a basis of U, take a basis of W and take the space spanned by the union of these two bases.
Hope that helped!
First, thank you for your help!
Would this not be the entire plane? My linear algebra is a little rusty :smile:, but I am thinking that the basis for U is some vector that points in the direction of the line y = -2x, and the basis for W is some other vector that points in the direction of the line y = 3x. The span of the union (addition) of these two vectors would be the whole plane.
micromass said:
Yep! We have
[tex]U+W=\mathbb{R}^2[/tex]
Quite boring isn't it? :biggrin:
Haha, yes it isn't all that exciting. This was just an example I thought up to try to get a geometric meaning for the sum of subspaces. I was hoping that this wouldn't tangent into more questions (because of the title :smile:), but it just might.
The definition of the sum of two subspaces given in the book I am using to brush up is this:
Given subspaces U_1, U_2, ..., U_m, the sum of these subspaces is denoted by U_1 + U_2 + ... + U_m and is defined as {u_1 + u_2 + ... + u_m : u_1 in U_1, u_2 in U_2, ..., u_m in U_m}. I hope this notation isn't confusing.
Using this definition, I am not seeing how we get R^2 in the example I am using.
Excellent question. It is indeed true that U+W is defined as
[tex]U+W=\{u+w~\vert~u\in U, w\in W\}[/tex]
However, the definition is not handy to work with. I prefer to use the equivalent
[tex]U+W=span(U\cup W)[/tex]
because you can easily calculate this.
But let's get back to your question. Can we show, using the definition, that
Yes! In fact, what we must do is for every [itex](x,y)\in \mathbb{R}^2[/itex], we must find elements u and w of U and W such that u+w=(x,y).
Now, an arbitrary element of U has the form u=a(1,-2) for some a. Analogously, w is an element of W and thus has the form b(1,3).
So, we have to find a and b such that (x,y)=a(1,-2)+b(1,3). This yields a system of equations
[tex]\left\{\begin{array}{c} x=a+b\\ y=-2a+3b\\ \end{array}\right.[/tex]
which you can easily solve.
For example, for (x,y)=(0,5), we have (0,5)=-(1,-2)+(1,3)=(-1,2)+(1,3). So we have expressed (0,5) as sum of vectors in U and W. We can do this with any vector by solving the above system.
