Why does the summation of even integers result in infinity?
The discussion centers on the concept of summing even integers in quantum mechanics, specifically addressing why the sum of 1 over all even integers results in infinity. The lecturer explains that since there are infinitely many even integers, the sum of 1 for each of these integers also diverges to infinity. Participants clarify that summing a constant value, like 1, over an infinite range leads to an infinite result, regardless of whether the index appears in the summation. The key takeaway is that the definition of an infinite series applies here, allowing for the summation of a constant across an infinite set. This understanding resolves the confusion regarding the treatment of sums without explicit terms.
BOAS
Hello,
in my QM class we arrived at the expression ##\langle \hat{H} \rangle = \Sigma_{even n} |C_n|^2 E_n = \frac{24}{n^2 \pi^2} \frac{\hbar^2}{2m} \frac{n^2 \pi^2}{L^2}##.
The n terms cancel and we are left with ##\langle \hat{H} \rangle = \frac{12 \hbar^2}{mL^2} \Sigma_{even n} 1##.
My lecturer said that this sum is infinity, since the number of even integers is infinity. Why is this the case when there are no n terms for the sum to act upon?
##\Sigma_{even n} n = \infty##, but I don't understand why ##\Sigma_{even n} 1 = \infty##
Mathematics news on Phys.org
BOAS said:
Hello,
If you add 1 10 times, you get 10.
If you add 1 100 times, you get 100.
If you add 1 1000 times, you get 1000.
If you add 1 10000 times, you get 10000.
See why ##\displaystyle \lim_{K\rightarrow +\infty} \sum_{n=0}^K 1## is ##+\infty##?
I understand what the sum to infinity means.
I don't think I have come across a sum over some index, where the index is not present and yet we still perform a sum.
##\Sigma_{n} n## and ##\Sigma_n 1## don't appear to be the same thing, and yet they are treated the same. That's what I don't really get. I can accept that that is how things are done, but was wondering if there was a reason.
While often the term being summed depends on the summation index n, there is no reason why this should always be the case.
##\displaystyle \sum_{n=0}^\infty 1=+\infty## is a straightforward application of the definition of an infinite sum, or series.
The partial sums get as big as you want when you keep adding 1's, so the series goes to infinity.
Ok, if I'm meant to read ##\displaystyle \sum_{n=0}^\infty 1## as the sum of 1 from zero to infinity, that's fine.
Thanks for your help.
For a sequence (a_n)_{n \in \mathbb{N}} you can form the series \sum_{n=0}^\infty a_n = a_0 + a_1 + a_2 + \dots.
If you take the sequence a_n = 1 and plug it into the expression above,
then you get the series \sum_{n=0}^\infty a_n = \sum_{n=0}^\infty 1 = 1 + 1 + 1 \dots.
Or consider the partial sum s_k = \sum_{n=0}^k a_n = a_0 + a_1 + \dots + a_k. If you plug in the sequence a_n = 1, then you get the partial sum s_k = \sum_{n=0}^k a_n = a_0 + a_1 + \dots + a_k = \underbrace{1 + 1 + \dots + 1}_{\text{k+1 summands}}.
In fact:
##\displaystyle \sum_{n=1}^m a##
is multiplication of ##a## by ##m##
It might be useful to think about the definition of the summation function as ##\sum_{n=0}^Nf(n)=f(0)+f(1)+f(2)+\ldots+f(N)##. Then ##f(n)=1## for your example and the definition works. Usually this is written with ##f(n)=a_n##, but for some reason when I saw it with ##f(n)## for the first time it clicked better for me.
