Summing sinusoids of different frequency
  • Context: Undergrad
  • Thread starter Thread starter funnyguy
    Frequency Sinusoids
The discussion revolves around the possibility of combining sinusoids of different frequencies into a single sinusoidal function. Participants explore both general and specific cases, including the mathematical transformations involved and the implications of summing sinusoids with different frequencies.
  • One participant inquires about combining sinusoids of the form Acos(2παt + φ) + Bcos(2πβt + χ) into a single sinusoid, expressing interest in both a general and a simpler case.
  • Another participant presents trigonometric identities to break down the components of the sinusoids but questions the utility of these identities in achieving the desired combination.
  • Some participants note that summing sinusoids of different frequencies can result in non-sinusoidal shapes, raising doubts about the feasibility of representing such sums as a single sinusoid.
  • There is a mention of the Fourier series, suggesting that while any repeating function can be expressed as a sum of sinusoids, the specific case of combining two into one remains uncertain.
  • One participant asserts that functions that are linearly independent cannot be summed into a single function, drawing an analogy with other mathematical functions.
  • Questions arise regarding the period of the sum of sinusoids with different periods, with some suggesting that the resulting waveform would have a period equal to the least common multiple (LCM) of the individual periods.
  • A later reply emphasizes that if the ratio of the periods is not a rational number, the sum will not be periodic, providing an example of a non-periodic function.
  • Finally, a participant states that two different pure sine wave frequencies cannot be summed to yield another pure sine wave frequency.
Participants express differing views on the possibility of combining sinusoids into a single sinusoidal function. While some agree that it is not feasible, others explore the mathematical implications and transformations without reaching a consensus.
Participants highlight limitations related to the linear independence of functions and the implications of summing sinusoids of different frequencies, but do not resolve these issues.
funnyguy
I'm curious if there is a way to combine sinusoids of multiple frequency into a single sinusoid?
For example, I'm looking for a way to combine:
Acos(2παt + φ) + Bcos(2πβt + χ) where A, α, φ, B, β, χ are scalar constants and α & β represent the frequency.
I'd even be interested in a less complex solution to:
cos(2παt) + cos(2πβt)
if this is much simpler than the general form above.
I found an incomplete explanation on here that does a transform and then recombines using complex numbers ending up with a cosine with an arctangent inside.
https://www.physicsforums.com/showthread.php?t=372263
However, explanations of the process are probably better than just a discrete example alone.
Mathematics news on Phys.org
cos(a+ b)= cos(a)cos(b)- sin(a)sin(b)
[itex]cos(2\pi\alpha t+\phi)= cos(2\pi\alpha t)cos(\phi)- sin(2\pi\alpha t)sin(\phi)[/itex] and
[itex]cos(2\pi\beta t+\chi)= cos(2\pi\beta t)cos(\chi)- sin(2\pi\beta t)sin(\chi)[/itex]
I don't think trig identities are going to be much help.
Acos(2παt + φ) + Bcos(2πβt + χ) = A(cos(2παt)cos(φ) - sin(2παt)sin(φ)) + B(cos(2πβt)cos(χ) - sin(2πβt)sin(χ))
Which has turned a sum of 2 sinusoids into 4 products and 3 summing operations on 8 sinusoids. This is kind of the opposite direction of where I was looking to go. I'm trying to figure out if there's a transformation I can use to get this all inside of a single sinusoid function, even if there is a trig function inside the sinusoid.
Summing sines of different frequencies can yield very NON sinusoidal shapes. Why do you expect to use a single sine function to describe non sine shaped functions?
i.e. The sum of all odd harmonics yields a square wave.
I don't expect to, I asked if it was possible.
I know it is possible to write any repeating function as a sum of sinusoids (Fourier?) but I was just curious if there is a process to combine a sum of 2 into 1. I'm mainly interested for representing purposes, I just wanted to see if there was a way to represent the sum mathematically without both sinusoids needing to be shown. Maybe it could be represented as a series?
Functions that are called linearly independent cannot be summed into a single one.
Sines of different frequencies are no different in this regard than trying to sum together, say, the functions Bz and Bz^2 into a SINGLE power in z.
What about the period of the sum of sinusoids of different periods? What would that be?
It would be a repeating waveform, of period equal to the LCM of their periods. Try some sketches and discover for yourself.
To give an example, if the ratio of the periods is not a rational number, the sum will not be periodic.
##f(x)=\sin(x) + sin(\pi x)## is not periodic.
The short answer is no. Two different pure sine wave frequencies can not be summed to another pure sine wave frequency.
