Summing sinusoids of different frequency
  • Context: Undergrad
  • Thread starter Thread starter funnyguy
    Frequency Sinusoids
The discussion centers on the impossibility of combining sinusoids of different frequencies into a single sinusoid. Specifically, it addresses the expression A*cos(2παt + φ) + B*cos(2πβt + χ) and highlights that while any periodic function can be represented as a sum of sinusoids (Fourier series), two distinct sine waves cannot be simplified into a single sine wave. The conversation also touches on the implications of summing different frequencies, which can yield non-sinusoidal shapes, such as square waves from odd harmonics.
  • Understanding of sinusoidal functions and their properties
  • Familiarity with Fourier series and transformations
  • Knowledge of trigonometric identities and their applications
  • Basic concepts of periodicity and waveforms
  • Study Fourier series and their role in representing periodic functions
  • Explore the concept of linear independence in function summation
  • Investigate the implications of summing sinusoids with different frequencies
  • Learn about the least common multiple (LCM) in relation to periodic waveforms
Mathematicians, physicists, audio engineers, and anyone interested in waveforms and signal processing will benefit from this discussion.
funnyguy
I'm curious if there is a way to combine sinusoids of multiple frequency into a single sinusoid?
For example, I'm looking for a way to combine:
Acos(2παt + φ) + Bcos(2πβt + χ) where A, α, φ, B, β, χ are scalar constants and α & β represent the frequency.
I'd even be interested in a less complex solution to:
cos(2παt) + cos(2πβt)
if this is much simpler than the general form above.
I found an incomplete explanation on here that does a transform and then recombines using complex numbers ending up with a cosine with an arctangent inside.
https://www.physicsforums.com/showthread.php?t=372263
However, explanations of the process are probably better than just a discrete example alone.
Mathematics news on Phys.org
cos(a+ b)= cos(a)cos(b)- sin(a)sin(b)
cos(2\pi\alpha t+\phi)= cos(2\pi\alpha t)cos(\phi)- sin(2\pi\alpha t)sin(\phi) and
cos(2\pi\beta t+\chi)= cos(2\pi\beta t)cos(\chi)- sin(2\pi\beta t)sin(\chi)
I don't think trig identities are going to be much help.
Acos(2παt + φ) + Bcos(2πβt + χ) = A(cos(2παt)cos(φ) - sin(2παt)sin(φ)) + B(cos(2πβt)cos(χ) - sin(2πβt)sin(χ))
Which has turned a sum of 2 sinusoids into 4 products and 3 summing operations on 8 sinusoids. This is kind of the opposite direction of where I was looking to go. I'm trying to figure out if there's a transformation I can use to get this all inside of a single sinusoid function, even if there is a trig function inside the sinusoid.
Summing sines of different frequencies can yield very NON sinusoidal shapes. Why do you expect to use a single sine function to describe non sine shaped functions?
i.e. The sum of all odd harmonics yields a square wave.
I don't expect to, I asked if it was possible.
I know it is possible to write any repeating function as a sum of sinusoids (Fourier?) but I was just curious if there is a process to combine a sum of 2 into 1. I'm mainly interested for representing purposes, I just wanted to see if there was a way to represent the sum mathematically without both sinusoids needing to be shown. Maybe it could be represented as a series?
Functions that are called linearly independent cannot be summed into a single one.
Sines of different frequencies are no different in this regard than trying to sum together, say, the functions Bz and Bz^2 into a SINGLE power in z.
What about the period of the sum of sinusoids of different periods? What would that be?
It would be a repeating waveform, of period equal to the LCM of their periods. Try some sketches and discover for yourself.
To give an example, if the ratio of the periods is not a rational number, the sum will not be periodic.
##f(x)=\sin(x) + sin(\pi x)## is not periodic.
The short answer is no. Two different pure sine wave frequencies can not be summed to another pure sine wave frequency.
