Suppose in the previous problem m3 balances the see-saw by pulling now
  • Thread starter Thread starter oneshot
The discussion revolves around a physics problem involving a seesaw, where a mass (m3) is attempting to balance the seesaw by applying a pulling force at an angle. The problem raises questions about the necessary force for balance and the role of the seesaw's mass.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the calculation of torque and the effects of the pulling force's components. Questions arise regarding the relevance of the seesaw's mass and how to approach the problem with the angle included.
Some participants have provided insights into breaking down the pulling force into components and its implications for torque. There is ongoing exploration of the assumptions regarding the mass of m3 and its effect on the seesaw's balance.
Participants note that the problem's wording may be unclear, particularly regarding the role of m3's weight and its impact on the seesaw while pulling. The discussion includes considerations of free body diagrams and the assumptions made about the seesaw's uniformity.
oneshot
balances the see-saw by pulling now on the end 1.5 m from the ful-crum at an angle of 30° from the horizontal as shown.
What force is necessary for balance?
See picture for both questions
The first question i got 31.4 kg
second question it added the angle and i don't know what to do with that.
Also I don't understand why does the mass of the seesaw doesn't matter?
Yes, looks good
forget about the mass of the person m3 and just consider a pull force as shown. Find its torque about the pivot by breaking it into its components, then proceed as before.
it is assumed that the see saw is uniform and its mass acts at the center (at the pivot), so if you use the pivot as the point about which to sum moments equal 0, does it make a difference?
I actually don't understand how does the breaking component work...
Fx cos 30 + Fy sin 30?
If you denote the pulling force as F, then the horizontal x component is Fcos30 and the vertical y component is Fsin30. The x component does not produce any torque about the pivot, since there is no perpendicular moment arm. Only the y component does produce torque.
oh make sense. but u said ignore m3? why? torque = rF , so the force does not include m3g?
The problem isn't worded that good, but presumably, the person called 'm3' is standing on the ground as (s)he pulls, so his or her weight does not act on the seesaw (draw a free body diagram of the seesaw), only the pulling force F acts on it.
oh ok thanks!
  • · Replies 24 ·
