Supposedly easy physics problem =( [projectile]
  • Thread starter Thread starter akshajkadaveru
    Physics Projectile
44 replies · 6K views
akshajkadaveru said:
HOLY MOLY...in all honesty.. am i over complicating this ?
Quite possibly.
so for D... i already have the x y values and the angle right? so now i just have to plot them or something >
Plot them if you wish, but to answer the question you should use algebra and calculation.
If the horizontal and vertical velocities are u and v respectively, what is the overall speed, and what is the angle of it?
i know how to find the angle.. but how do i find the overall speed... is that by the pythagorean theorem and i plot that based on what i got for the V0x and v0y?
Yes.
2^2+3.46^2=15.97
sqrt(15.97)
3.99 m/s
tan^-1(3.46/2)= 59.97 degrees
3.99m/s @ 59.97 degrees'
2^2+3.46^2=15.97
sqrt(15.97)
3.99 m/s
You've used the initial vertical velocity. As a result, you've recalculated the initial angle and overall speed.
Use the vertical velocity when it hits the target.
ARGHGHGHH! so what i JUST did was wrong but what will my X and Y value things be then ?
You posted the correct final vertical velocity in post #27. Just use that instead of 3.46 in your calculation in post #36.
i didn't post anything on 27
so is it... 1^2+1.44^2=whatever
sqrt(whatever)= ______ @ tan^-1(1.44/1)?
will that be my answer?
Where are you getting 1m/s from for the x direction?
oh... i thought that't just the length of how far the thing went... how do i get that then >?
No, you can't add a velocity to a length, or a velocity-squared to a length-squared. It makes no sense.
To apply the arctan formula and Pythagoras, you need two things of the same type at right angles - both lengths, or both velocities, or both accelerations...
What is the initial horizontal velocity? What is the horizontal acceleration? So what is the final horizontal velocity?
