Swimming with current, velocity, angles
The discussion revolves around a physics problem involving two individuals attempting to rescue a person drowning in a river. The scenario includes variables such as the river's current velocity, the swimming speeds of the rescuers, and the distances involved. Participants are exploring how to determine the optimal angle for one rescuer to swim in order to minimize the time taken to reach the drowning individual.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of swimming directly across the river versus at an angle, questioning how the river's current affects the swimmer's effective velocity. There are attempts to calculate angles and velocities using trigonometric relationships and vector addition.
The discussion is ongoing, with participants sharing their thoughts on the calculations needed to determine the correct angle and velocity. Some have provided diagrams to illustrate their reasoning, while others express uncertainty about the necessary equations and concepts, particularly regarding vector addition and trigonometry.
Participants are grappling with the complexities of vector dynamics and the need for precise calculations to solve the problem. There is a mention of the law of sines and cosines as potentially relevant to the discussion, indicating the mathematical depth required to address the problem effectively.
Chemfriend
Hi, I have a homework and I am not sure about some things.
1. Homework Statement
Person A and person B are next to river. Velocity of river is 1 m/s. There is a person drowning 30 m from shore. He doesn´t move, because there is a something, which he can hold. People A and B are 40 far from him (40 m along river, but 50 m if they swum). Person A is a very good swimmer (1,25 m/s) so he decided to jump into the river and swum across the river to person C. Person B can run 4,75 m/s but swims only 1 m/s. So, he runs and then jumps into the river and swims.
a) What angle should person A swim to person C, in order to be in the shortest time to person C?
b) What time would it take?
c) How much time should person B run (and then jump into the river) to get to person C at the same time as person A?
d) How many m has person B already run on the shore?
It is pictured in image, which i painted: https://s22.postimg.org/y4v78ilkh/whatever.png
v = d/t
Pytagoras sentence (50^2=30^2+40^2)
cos(-1)(0,8)=36,869°
I tried to draw the image in paint.
I counted 50 m with pythagoras sentence.
I can also count the angle of swimmer A (36,87°).
Now, I am not sure how to count velocity of person A. I know velocity of swimmer (1,25 m/s), I know velocity of river (1 m/s). And now to count velocity of swimmer A in river? Should I sum the velocities (1+1,25 = 2,25 m/s) Or is is different because of angle? Now the time will be easy to count (v=d/t). Now I don't know the time, so I can't solve person B.
I enclose image:
Think about what happens if A tries to swim directly across the river. What happens to him?
Then he is moving with river's current. If he swum directly across the river his velocity would be: v=sqrt((1,25)^2-(1)ˇ2) = 0,75 m/s ? But he is swimming with angle and this is the problem.
That's slower than someone who just floated in the river and was taken at ##1m/s## by the river's current?
I think that if he swum with the flow, I would have to sum the velocities (1+1,25=2,25 m/s). If he swum against the flow, it would be 1,25-1=0,25 m/s. And if he swum directly across the river? Now I am not sure, because you are right.
Okay. The first step is to work out what direction A moves if he tries to swim across the river. After that, you can work it out for an angle.
Hint: velocity is a vector.
Chemfriend said:
https://s12.postimg.org/dh5jgmazx/vector.png
I think this is it.
(v1)*(v2)* sin 90°?
You may need to revise vectors and vector addition. The swimmer's overall velocity will be the vector sum of the swimmer's velocity (relative to the river) and the river's velocity. In your diagram, you need to put the red and blue vectors end-to-end and the yellow vector should be the result.
This is then also the case where the red vector is at an angle.
These questions are going to be very difficult if you can't work with vectors.
Chemfriend said:
No. You have the river moving at an angle. Second, you can't just guess the angle. Although you could estimate it with a very accurate diagram.
You'll need to know the law of sines and law of cosines for this one.
Given your level of ability with vectors, you may find this a very difficult problem.
Chemfriend said:
Now this should be right.
https://s11.postimg.org/4n4mgkifn/thisshouldberight.png
The angle is 36,87 because of pythagoras sentence? (50^2=30^2+40^2) and then cos-1 0,8 = 36,87.
That's the angle of the direct line to C, which you can calculate immediately. The question is asking what angle A has to swin relative to the river to achieve this. That's a much harder question.
In any case, you'll need this for part b).
So we don't need the angle 36,87? Now it seems much harder as I thought. The only things we need are velocity of swimmer, distance to C (50 m) and velocity of river? SO we need to know what angle he needs to swim to achieve 50 m? Is this the hardest part or the rest is harder? Can you please give me just one equation? or to draw it? Now I have lost the idea.
He needs to swim at an angle so that when you add the river's velocity vector to his velocity vector, you get a vector at ##36.9°##. If you draw this on a diagram and use the law of sines you'll get the additional angle. The total angle must be greater than ##36.9°##, so that the river pushes him onto the real angle of ##36.9##.
I'll be offline now.
  • · Replies 30 ·
  • · Replies 16 ·
