Switch cover Snap-up spring mechanism?
The spring mechanism used in the switch cover discussed is commonly referred to as a "toggle mechanism" or "over centre mechanism." This mechanism allows the cover to snap up and down, maintaining its position until the spring tension is released. The protective cover is also known as a "Toggle Switch Position Indication Cover." For those looking to create a miniaturized version, understanding these mechanisms is essential, especially for projects requiring custom adjustments.
  • Understanding of mechanical engineering principles
  • Familiarity with toggle mechanisms
  • Basic knowledge of spring tension systems
  • Experience with custom mechanical design
  • Research "toggle mechanism design" for insights on mechanical functionality
  • Explore "spring tension calculations" to understand force requirements
  • Investigate "miniaturized mechanical components" for custom project applications
  • Learn about "mechanical CAD software" for designing custom parts
Mechanical engineers, product designers, and hobbyists involved in creating custom mechanical systems or miniaturized devices will benefit from this discussion.
ilik
Hi. I'm searching for a name of the spring mechanism that snaps-up and snaps-down this type of Switch cover https://cdn.sparkfun.com//assets/parts/6/9/9/0/11310-03a.jpg .
on the left side of this red cover, you can clearly see the spring and few other things, that makes it to resist any change of position of the cover, up to a point when spring releases the tension and let's the cover to snap up. same happens when snapping down.
i's sure in mechanical engineering it is a very known mechanism, and has a technical name like "snap-up tension spring" or "button snap spring" or something. so could anyone tell me it's name?
Toggle mechanism .
Over centre mechanism .
Toggle switch .
OCR said:
Or search this site... that's where you picture came from, I think.
https://www.sparkfun.com/categories/new_products
i know sparkfun sells it but i need to create miniaturized version of that cover with some custom adjustments for my project.
allright, thank you everyone. i come from neighboring field (Electronics engineering) and that's why i have no knowledge of even basic things in Mechanical engineering. on youtube, "Toggle mechanism" revealed many versions of similar systems. thanks for the help.
