Symmetric group (direct product and decomposition)
The discussion centers on the decomposition of symmetric groups, specifically whether symmetric groups \( S_n \) can be expressed as direct products of their proper subgroups. It is established that \( S_n \) cannot be decomposed into a direct product of two or more proper subgroups. Furthermore, while groups such as \( A_{n+2} \) and \( S_{n+k} \) contain subgroups isomorphic to \( S_n \), no symmetric group is isomorphic to a dihedral group. The conversation also touches on Cayley's theorem, which states that any finite group is isomorphic to a subgroup of a symmetric group.
  • Understanding of symmetric groups, specifically \( S_n \) and \( A_n \)
  • Familiarity with group theory concepts such as isomorphism and direct products
  • Knowledge of Cayley's theorem and its implications in group theory
  • Basic comprehension of composition series and subgroup structures
  • Research the properties of symmetric groups and their subgroups
  • Study Cayley's theorem in detail and its applications in group theory
  • Explore the Jordan-Hölder theorem and its relevance to composition series
  • Investigate the structure of alternating groups and their relationship with symmetric groups
Mathematicians, particularly those specializing in group theory, algebraists, and students seeking to deepen their understanding of symmetric and alternating groups.
Symmetryholic
I am looking for a mechanism to find a decomposition of symmetric groups. For finitely generated abelian group G, there is a mechanism to decompose G such that G is isomorphic to a direct sum of cyclic groups.
For symmetric groups, it seems a bit complex for me to find it.
For example,
(1) Is it possible for S_{n} to be decomposed as a direct product of groups?
(2) Is there any mechanism to find an isomorphic group of a direct product of symmetric groups? Let's say,
G = S_{n-2} \times S_{n-1} \times S_{n}
Any isomorphic group of the above G?
(1) No, you can't decompose the symmetric group into the direct product of two (or more!) of it's proper subgroups.
(2) Sorry, but I don't understand the question.
If we cannot decompose symmetric groups, question (2) might reduce to find isomorphic groups of S_{n}.
Is there any known group, let's say P, isomorphic to S_{n}? If so, by Caley's theorem, any group G is isomorphic to the subgroup of P. Is that right?
I'm not understanding you.
What do you mean by "isomorphic groups of Sn"? Groups isomorphic to Sn? You can take any set you like of size n! and define a group operation on it to make it isomorphic to Sn.
Yes, put P = Sn. Or do you mean something different?
No, just pick a group G larger than P. Cayley's theorem states that any finite group G is isomorphic to a subgroup of Sn, where n = |G| (it depends on G!).
For instance,http://at.yorku.ca/cgi-bin/bbqa?forum=ask_an_algebraist_2006;task=show_msg;msg=0044.0002"
Like A_{n+2}, is there any known group that has a subgroup isomorphic to S_{n}? A_{n+2} is the only group (different from S_n ) I have found so far.
Is there any dihedral group(or variants) of order m > n that has a subgroup isomorphic to S_{n}?
Right, A_{2n} is trivially isomorphic to S_n. Even more trivially, S_{n+k} has plenty of subgroups isomorphic to S_n for all k\geq 1. Continuing, so does S_n \times G for any group G... etc. You can construct as many as you like which is why I (and probably adriank as well) am confused by this "any known group" phrase.
I don't know then answer to your Dihedral group question off the top of my head. I'll think about it. Assuming you haven't already, see if you can figure out why the symmetric group can't be decomposed :-p
Not true: |A2n| = (2n)!/2, while |Sn| = n!. However, An+2 has a subgroup isomorphic to Sn, at least according to the post he linked.
As for the dihedral group question: I write Dn to mean the dihedral group of order 2n. Any subgroup of Dn is either cyclic or isomorphic to Dm, where m divides n.
Every dihedral group has its trivial subgroup isomorphic to S1. Every dihedral group also has a subgroup isomorphic to S2, which is a cyclic group of order 2. For S3, note that S3 is isomorphic to D3, so the dihedral groups that have a subgroup isomorphic to S3 are exactly the ones of the form D3n. Thereafter, no symmetric group is isomorphic to a dihedral group, so there are no more.
I meant to say " A_{2n} has a subgroup that is trivially isomorphic to S_n" :redface:
Alright, I guess that's true. :)
the analog for non abelian groups, of the direct decomposition of abelian ones, is the filtration by subnormal towers, used in galois theory. see the jordan-holder theorem. or the krull schmidt theorem.
I was going to list some composition series for the symmetric groups, but I had a feeling that those wouldn't be what he was looking for. I may as well do it anyway...
Here are composition series with the composition factors for the symmetric groups.
S_1 = \{\varepsilon\}
S_2 \rhd \{\varepsilon\}; factors C_2
S_3 \rhd A_3 \rhd \{\varepsilon\}; factors C_2, C_3
S_4 \rhd A_4 \rhd K \rhd H \rhd \{\varepsilon\}, where K = \{\varepsilon, (12)(34), (13)(24), (14)(23)\} and H = \{\varepsilon, (12)(34)\}; factors C_2, C_3, C_2, C_2
S_n \rhd A_n \rhd \{\varepsilon\}, n \ge 5; factors C_2, A_n
Thanks for all replies.
I have some further questions.
(1) Is it possible for S_{n} (n>=5) to be a product of its proper subgroups such that S_{n} = HK. H and K are proper subgroups of S_{n}.
(2) Is it possible for S_{n} to be a finite product of its proper subgroups such that S_{n} = H_{1}H_{2}..H_{k}, where H_{1}H_{2}..H_{k} are proper subgroups of S_{n}, where n >=5.
Lemma 1. S_{n} is generated by a=(1 2) and b=(1 2 3 ... n).(http://mathforum.org/library/drmath/view/51685.html")
My assumption is
If b \in A_{n} for n>=5, it is possible for (1). (Is this correct?)
(It's because a \in S_{2} and b \in A_{n}, and both S_{2}, A_{n} are proper subgroups of S_{n} ).
If b \notin A_{n}, I have no clue.
It's possible for any n > 2; take H = {e, (12)} and K = An. In that case, HK = An ∪ (12)An = Sn; this is the union of the even permutations of Sn and the odd permutations of Sn.
Thanks, adriank.
Is it possible for A_{n} to be a product of its proper subgroups as well such that A_{n} = H_{1}H_{2}..H_{k}, where H_{1}H_{2}..H_{k} are proper subgroups of A_{n}, where n >=5 ?
This problem is hard for me as well because I could not find any pattern on proper subgroups of A_{n}.
  • · Replies 26 ·
